Right rear turn signal and brake light on 378
Discussion in 'Peterbilt Forum' started by adayrider, Mar 2, 2019.
  1. adayrider
    adayrider Road Train Member
    1,289
    1,732
    May 7, 2018
    Right turn brake light not working on a 1996 378. No power at plug at rear of truck. Anybody know where the next plug is up along the frame is? Front turns work, trailer turn brake lights work so it is in the the harness running the rear of tractor. I figure there is a plug up along the frame maybe under bunk or cab that is the problem.
    Any help would nice. Thaks
    Upinsmoke Thanks this.
  3. blairandgretchen
    13,426
    72,379
    Dec 9, 2011
    South west Missouri
    Something in my brain is saying turn signal switch itself - but I can’t remember why.
    Upinsmoke, wore out and adayrider Thank this.
  4. adayrider
    1,289
    1,732
    May 7, 2018
    Thanks, but every other right turn on the truck and trailer works. all brake lights work but right rear tractor. Turn switch only year old. I'm going to follow the wiring up along left frame in the morning and see where it goes. There is only 5 wires in it, L/R turn and brake are same 2 wires, 1 for running lights, 1 for back up, and 1 ground.
    Upinsmoke and blairandgretchen Thank this.
  5. kemosabi49
    10,739
    46,240
    Jan 13, 2013
    SW Arkansas
    Tractor brake and turn signals run through the turn signal lever/switch while the trailer does not
  6. adayrider
    1,289
    1,732
    May 7, 2018
    Ok then, I will buy another switch and see what happens.
    Thanks
