I finished the first 13 days of training in Millington. Fast paced and thought I was on my way. Left Millington Mar 12. Then had a 7 day delay before road training at the closest Swift terminal which was to begin on March 21. Here is the breakdown of my training period so far:
Monday, Mar 21: NO training. Sat at hotel. Okay(?)
Mar 22: 10 minutes of shifting instruction, then 30 minutes road training.
Mar 23: 20 minutes of backing practice.
Mar 24: 1:45 road training. Finally!
Mar 25: 2 hours road training. Training time getting better
Mar 26 and 27: off. Drove home for weekend
Monday, Mar 28: No road (or backing) training-again. Sat in an orientation class for new company drivers (nothing like putting the cart before the horse?), and did 10 minutes of simulator training.
Mar 29-Apr 3: No training - again! That is 10 days between time BTW and then continuing training planned to restart Mon., Apr. 4.
I'll believe it when I am actually BTW driving.
A little over 4 hours of BTW road training in 3 weeks is absolutely ridiculous! I can't blame the instructor. He needed to take the time off. I am irritated with Swift. You would think Swift would have a back-up road instructor for those times that the main instructor has family matters to attend to. Making students sit for 10 days at a time, then expect us to not to slip back in our skills (due to very little BTW experience) is not my idea of quality training.
My first impressions of Swift were positive, but I am starting to believe the "left hand doesn't know what the right hand is doing." I sure hope the quality of training -or lack there of - is not an indication of Swift as a company. Before someone states "learn patience and get used to delays, that is part of trucking," I say: I am aware of this, but you would think students could -at the least - get through a 20 day school in less than 5+ weeks!I don't even have a test date scheduled. That may be a good thing, because no way in h*** have I received the amount of BTW drive time to be prepared with passing the DOT test. Not to mention my backing skills are probably eroded. Thanks for listening to my venting.
Road training?
Discussion in 'Swift' started by Buckeye 'bedder, Mar 31, 2011.
JunkHauler, tazaaa, JustSonny and 2 others Thank this.
You would be suprised how easy that dot test really is. Once you have been on the road a bit youll look back and just say wow. I didn't go threw swifts cdl school so I can't answer to anything on that, but there is a wait for mentors so once your done be prepared to wait somemore. The main thing here is to keep your eye on the goal you will get there.
JunkHauler and scottied67 Thank this. -
Keep your pretrip fresh in your head, and continue to practice the air brake test steps, count 'em off with your fingers as you go through them so you know you got all the steps down-- The air brake test is the number 1 thing they are looking to see if you know, driving and pretrip about equal below that.
Rotten Thanks this. -
Hang in there, Chum! With 1000+ posts to the board, you'll do just fine . .
S - static
A - applied
W - warning (low air buzzer)
S - spring (brakes engage)
G - govenor
P - parking (and trailer)
S - servicescottied67 Thanks this. -
Buckeye what terminal are you out of?
So,the more posts we have,the better we are "out" there?
After all these years..Finally,-I have found the answer.
Buckeye 'bedder Thanks this. -
C-- Air compressor governor Cut-In
O-- Air compressor governor Cut-Out
L-- Low Air Pressure Warning
A-- Applied Air Brake Test
P--Pop Out Test
S-- Static Air Brake Test
T--Tug Test
Downshifting, yes the best way to learn is to do it early and often (practice). The way (I'm sure you know already) I learned was to memorize the speeds for each gear. So when you're at the speed (or close to it within about 3-5 miles per hour either way) feather up the throttle and as it drops from 1400-1500 down to 1100-1300 (each truck is a little different) there is a sweet spot that you will be able to then shift to the lower gear-- engine speed and rpms matching up in other words.
OK Here are my shift up speeds for each gear on my 9 speed:
- Granny gear-- 1MPH shift up
- 1st gear-- 2 MPH shift up
- 2nd gear--10 MPH shift up
- 3rd gear--15MPH shift up
- 4th gear 20MPH shift up
- 5th gear 25MPH shift up
- 6th gear 35MPH shift up
- 7th gear 45-50MPH shift up
Now they say in the book don't do this don't do that like shifting through an intersection, shifting downhill etc. There are times when it will be necessary but practice it on flat ground and master it before you try it on the mountain. I can think of a quick example of where it is necessary and that is in Colorado on HWY 50 between Maysville and Doyleville there are some places where you're bebopping along about 7th gear 45 MPH and you see up ahead some 20 MPH horseshoe turns. So all this time up and down the Rockies there you've been saving your brakes using your skills and training now you use them to slow you down enough to catch that next gear down. But because it is downhill and you cannot afford to miss the gear I recommend slowing down to a slamdunk speed you know it will go in for sure. Maybe 30 MPH 1000 rpm feather up throttle one time and put her in gear. Rinse and repeat, because 20 MPH turn is gonna be 4th gear full on engine retarder brakes and all. After you come out of that give your brakes a breather-- the best thing for hot brakes is to keep driving. If you must pull over perhaps pop only the tractor brakes and let the trailer brakes cool for a time then put the tractor in granny gear, set trailer brakes and release tractor brakes for a while let em cool, (engine off) stay in the seat so you can control the situation.Buckeye 'bedder and Rotten Thank this.
