Rock the size of a brick in my front pod
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by Frank Speak, Jun 30, 2018.
  1. Frank Speak
    Frank Speak Road Train Member
    4,519
    13,821
    May 3, 2016
    I was offloading into a pig and the center pod (I always start with center) was empty in maybe 10 mins at most. Started the front pod and it took forever. When it finally went empty the lever wouldn’t close on the product valve.
    Ended up being a rock almost the size of a brick wedges up in there.
    That was a first for me. Recall, I just started this gig 3 months ago.
    VIDEODROME and Bud A. Thank this.
  3. Air Cooled
    Air Cooled Road Train Member
    1,315
    1,094
    Jul 17, 2011
    Baltimore
    Air assist lids or manual? Do you have vibrators/shakers in the trailer? When the hoppers are empty I would just run it while tapping the trailer all around with a rubber mallet to loosen up the buildup. Then, close the product and line valve to build pressure through the aerator. Open the the product valve with the line valve closed-you’ll heat lots of dry chunks being fed through. Once the pressure is relieved finish up with the line valve from the blower.
    bottomdumpin and Brettj3876 Thank this.
  4. Frank Speak
    4,519
    13,821
    May 3, 2016
    Manual lids and vibrator/shakers
  5. Air Cooled
    1,315
    1,094
    Jul 17, 2011
    Baltimore
    Be thankful you have manual lids. The air assist are prone to so many problems and require constant maintenance. I hated them. Just keep using those shakers and build pressure in that tank when empty to flush everything out.
    bottomdumpin and Frank Speak Thank this.
  6. Air Cooled
    1,315
    1,094
    Jul 17, 2011
    Baltimore
    Also, when empty, open and close that product valve when flushing it out to break up any buildup at that point.
    Frank Speak Thanks this.
  7. speedyk
    speedyk Road Train Member
    1,837
    2,470
    Apr 8, 2015
    Did they take the valve off to get it out?
  8. Frank Speak
    4,519
    13,821
    May 3, 2016
    Yes, one of our drivers was there going into the silo. He showed me what to do.
  9. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,058
    Nov 18, 2014
    Land of local
    Yup that's how I would do it every time. Also start with the rear pod, if you plug up its a lot easier to suck it back in that last pod than say 1st or middle
