What are the pros and cons of selective catalytic reduction and exhaust gas recirculation? I've read that SCR reduces the life cycle of the powertrain, but that EGR isn't much better. Are there any other solutions to meeting EPA emissions standards?
SCR vs EGR
Discussion in 'Trucking Industry Regulations' started by OccamsRazor, Nov 30, 2017.
Both of em to reduce NOx pollution to save our glory California.
here is some theory of combustion.
To increase power of combustion from same amount of fuel used you need to increase temperature of combustion by inducing more oxygen . But it will increase NOx in exhaust gases.
EGR designed to reroute some exhaust gases to replace O2 and decrease combustion temperature in cylinder to decrease NOx pollution.
Now engine starts smoking because not enough O2 to burn fuel completely . Californians not happy.
OK here solution, readjust EGR to put less exhaust in intake and attach SCR to reduce NOx.
We don't care about life cycle of powertrain. We need healty ppl in California.KB3MMX, bottomdumpin and Bean Jr. Thank this. -
EGR......installed on the engine and thus has a direct effect on the engine. -
DEF is part of the SCR system, it is injected into the exhaust after the DPF has done it's job. Most of the engine manufacturers except International went with SCR initially. International tried and failed to meet the pollution standards with just EGR (with the dreaded Maxxforce engine), but eventually gave up on that plan. Now all modern, complaint engines use both EGR and SCR.Last edited: Dec 1, 2017
daf105paccar Thanks this. -
Diesel Particle FILTER. -
If only they could make a dpf that spits out charcoal brickettes when it accumulates carbon.
The dpf is the major problem. It creates a lot of back pressure. Egr is also a problem recirculating exhaust gas with soot in it right back to the intake. I'd rather have no egr and use more def.not4hire and Snailexpress Thank this. -
Kind of a moot point. All diesels, even with SCR units, have EGR systems on them. It is a team thing. One either has EGR only, or EGR/SCR. There is no SCR only system. DPF is another thing altogether. That is for soot. EGR and SCR are for NOx reduction. At least the SCR systems allow for greatly reduced EGR function.
In the USA all SCR have a EGR system.
In the EU some went back to SCR only but that has lead to a very high rate off DEF usage.
The jury is still out on which way is best.Accidental Trucker Thanks this.
