Shifting with bad clutch brake?
Discussion in 'Experienced Truckers' Advice' started by Oldironfan, Jul 18, 2018.
  1. Oldironfan
    Oldironfan Road Train Member
    5,777
    5,543
    May 22, 2017
    Is this possible? I've touched on this a bit before. Truck is a 14 579 Pete. I'm not sure but some have told me it might be a solo clutch, and it's hydrolic also. Petal does not grab until tip top of pedal release. Some times, splitting the 13 speed down seems very slow to do so. Some times I'll go to down split let off throttle 99% and then mash throttle and it will over rev engine, so I let off throttle until engine drops again to about 1000 rpm to grab split down gear.
    Company truck they don't seem to be to concerned.
  3. kemosabi49
    10,694
    45,939
    Jan 13, 2013
    SW Arkansas
    Clutch brake does not have anything to do with shifting. Only when stopped.
    rank, Grubby, snowwy and 7 others Thank this.
  4. Bean Jr.
    Bean Jr. Road Train Member
    5,511
    9,807
    Mar 30, 2014
    Right! One should never use the clutch brake while shifting.
    rank, Grubby, SingingWolf and 2 others Thank this.
  5. Oldironfan
    5,777
    5,543
    May 22, 2017
    So would it be that the adjustment is bad? Solo clutch type issue?
  6. pmdriver
    pmdriver Road Train Member
    2,338
    3,503
    Nov 14, 2017
    if it is releasing at the top of the pedal the clutch is never fully disengaging. Get it adjusted properly before it is gone.
  7. InTooDeep
    4,981
    37,363
    Jan 17, 2016
    Carmichael CA
    It sounds like it is already gone if it is slipping like that. I'd try adjusting it first and see if it helps. Clutch brake only comes into play last 1/4 of travel just before the floor
    rank and Grubby Thank this.
  8. supersnackbar
    19,269
    47,965
    Aug 19, 2007
    Your Town, USA
    There should be 1/4 to 1/2 inch freeplay at the top, even on hydraulic actuated clutches...definitely needs adjusted....why use a clutch when shifting anyway?
  9. pmdriver
    2,338
    3,503
    Nov 14, 2017
    It is actually gone, better nose it towards the shop before having to pay for the wrecker to get you moving again.
    Grubby Thanks this.
  10. Fold_Moiler
    Fold_Moiler Road Train Member
    1,926
    3,528
    Mar 17, 2017
    Clutch is out of adjustment.
    If the brake is bad it’s hard to get it in gear at a stop. Usually gotta jam it and it will grind a little.
  11. Espressolane
    17,603
    107,984
    it Sounds like you may have more of a problem than just a clutch out of adjustment. The new hydraulic systems are supposed to have a certain amount of self adjustment.
    When splitting up or down, it needs to break torque for a moment. This will unload the transmission and gears. That will allow for the overdrive gear to move out of the way. This is air operated, if it is hanging up you may have a bad actuator or an air leak in that part of the system. Have never had to use the clutch to split on any 13,15 or 18 speed. All throttle control. Then float the rest once moving.
    Bean Jr. Thanks this.
