Should I be idleing?
Discussion in 'Questions From New Drivers' started by Mrh2008, Nov 10, 2012.
  1. Mrh2008
    Mrh2008 Road Train Member
    1,288
    310
    May 25, 2012
    Mesa, AZ
    I'm out here in Ft. Bridger, WY. 17 degrees, low of 13. My trainer told me last winter that its a good idea to idle under 19 degrees so your fuel doesn't gel, is 19 degrees the magic number?
  3. H-D Road Glide
    H-D Road Glide Light Load Member
    131
    75
    Jun 25, 2012
    Central Florida
    I idle under 20 and over 75.
  4. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,730
    Jan 30, 2010
    keep stroking.
    hah i'd idle at 40 or below justn to stay warm! dang the fuel!
  5. Noggin
    Noggin Road Train Member
    2,494
    977
    Apr 10, 2011
    Houston, TX
    Most anti gels will go down in to the negatives, but its good to keep the tank stirring. A good steady wind even at 10 degrees will gel it up no time. But like super said, #### the fuel, stay warm...lol
  6. Mrh2008
    1,288
    310
    May 25, 2012
    Mesa, AZ
    Silly question, are anti gel additives already in the fuel or are they solely additives that I must mix in?
  7. scottied67
    scottied67 Road Train Member
    10,818
    12,622
    Mar 14, 2010
    california norte
    I would generally idle for an hour every 4 or 5 hours at really low temperatures. The qualcomm has a sensor display of many things, one of which is fuel temperature. I've watched it get down into the 40's and idling will get up over 100 degrees.
  8. Noggin
    2,494
    977
    Apr 10, 2011
    Houston, TX
    Not silly. You can buy them at the truck stops. Just look at the bottle for how many gallons it treats. Split em between your tanks (I assume you have 100 gal tanks?) when you fuel, that way it gets mixed in good.
  9. DrFlush
    DrFlush Road Train Member
    1,297
    2,707
    Mar 22, 2011
    Upstate NY
    Fuel in southern states is not always treated, as for fuel gelling, somewhere between 10 and 15 degrees is the usual temps that it will start to gel depending on the fuel quality. In the winter if your not sure if the fuel is treated , add anti gel, you can ask at the fuel desk if their fuel is treated. I always carry fuel treatment in a side box so I can add it if I am buying fuel in the south and headed north.
  10. Numb
    Numb Crusty Curmudgeon
    4,055
    9,298
    Jan 30, 2012
    Charlotte, N.Carolina
    it's not the fuel in tank I worry about,it's those little lines to the injectors that gel first. had them gel years ago when it was -40 below up in Quebec. had to stop every 20 minutes or so and the lines would thaw from the heat of the engine.lol. learned my lesson, add the additive under 15 or so. I was running southern fuel with no inline fuel heater or additive.
  11. djtrype
    djtrype Heavy Load Member
    935
    545
    Jan 3, 2009
    New Orleans
    In case you're wondering what the bottle looks like, this is what I usually get at the truck stops.
    Mrh2008 Thanks this.
