Should I go o/o?
Discussion in 'Questions From New Drivers' started by Gsm, Jul 14, 2018.
  1. Gsm
    Gsm Light Load Member
    108
    198
    Jul 14, 2018
    I have zero mechanical abilities... if I buy new will I regret it??
  3. 201
    201 Road Train Member
    12,787
    26,314
    Apr 16, 2014
    high plains colorado
    Welcome aboard. Well, there was a time if you bought a truck without any mechanical skills, you were a dad-burned fool. Today, with trucks being so much more reliable, it's entirely possible to do that. I'd say the bigger question, is can you handle the business end of it. It's where I made my big mistake. I did all my own repair work, but lacked the business smarts. Pretty tough these days making it as an O/O, especially with repairs, and all trucks break.So, I'd say don't do it. So many good company jobs out there today, might take a couple to find a home, but O/O's don't make a heck of a lot more at the end of the day ( or year), however, it is rewarding having your own. Sadly, that doesn't pay the bills. Insurance today will kill ya', too. Good luck.
    dunchues Thanks this.
  4. stillwurkin
    stillwurkin Road Train Member
    1,756
    2,856
    Dec 2, 2017
    The more small mechanical things you can do to your truck, the better. Grease it, yes that means get under it. Look for anything that could be loose, falling off. Leaks, belt wear. Just because you can't rebuild your engine etc doesn't mean you can't do the smaller stuff. Trucks take a beating on a lot of these bumpy roads. Spring u-bolts, suspension bushings. The guys at the TA, speedco, or where ever point out some things. Bottom line its your truck, if you are the owner opp. They don't have skin in the game. Not saying you have to do it this way, but save $ where you can. Catching a potential problem before you are setting, waiting for road service.
  5. Ridgeline
    22,725
    123,408
    No. If you want to know why, look at some of the o/o threads in the owner operator section of the forum.
    stwik and 201 Thank this.
  6. Mattflat362
    Mattflat362 Road Train Member
    2,711
    6,228
    Feb 18, 2015
    Avon Lake, Ohio
    Just got get a good paying job with bennies somewhere! I have never ever seen so many help wanted signs in my life!
    Ohio is booming at least!
    Seriously man.....it is SOOOO much work going O/O...I don't know if I would do it again.
    You are either sleeping or driving or wrenching or thinking about the company and that is it. Everything else suffers.
    201 Thanks this.
  7. Crazytrucker77
    Crazytrucker77 Heavy Load Member
    848
    1,048
    Nov 23, 2014
    Grants Pass, OR
    Just because you don't know now doesn't mean you can't learn. There is enough sources out there to learn how to do the basic stuff. Get a good mechanic that will let you watch them or see if your company's mechanic will let you watch them do PM on your company truck. Being an O/O is not something to just jump into. You should take time to learn both the mechanical side and the business side. I kept track of my company trucks expenses for over a year and took every opportunity I could to get under the truck with the mechanics and help before I made the jump to O/O. I can tell you I only made a little over 6,600 dollars more my first quarter then I did as a company driver for the same company I am leased onto. That number is for four months also. IMO people become an O/O for the freedom they can have more then the possible money they can make. So take your time and soak in as much info as you can.
  8. Buckeye 60
    Buckeye 60 Road Train Member
    1,229
    1,269
    Apr 19, 2018
    been an o/o for a long time and I have gotten to the point of not doing much work at all on the truck use to do almost everything just don't want to spend my days off turning wrenches have a good shop that I trust to do most of my work .. I don't think you have to have any more mechanical ability being an o/op than a company driver ... you need to learn the simple easy stuff as you go .... most of the problems today are with the electronics or def and your not going to be able to work on anyways
  9. Mattflat362
    2,711
    6,228
    Feb 18, 2015
    Avon Lake, Ohio
    At the very least you need to be a diagnostics EXPERT and have 2-4 off the beaten path shops within 60 miles of your parking spot that really know you and your rig and know what they are doing.
    Just my .02
    blairandgretchen Thanks this.
  10. Moose1958
    Moose1958 Road Train Member
    15,296
    33,965
    Dec 17, 2010
    Williesburg, Virignia
    At the risk of being called everything from a know it all to a bad guy, if you have to ask that question you are not ready.
  11. blairandgretchen
    13,936
    76,626
    Dec 9, 2011
    South west Missouri
    Know it all bad guy.
    Bumper Thanks this.
