Should we hold out for longer accept the aisle?
Discussion in 'Questions From New Drivers' started by BAG, Oct 25, 2013.
  1. BAG
    BAG Bobtail Member
    10
    Sep 22, 2013
    If you press the clutch pedal and the gear can be engaged? Or coupling from one, does the pedal and instead provides the right foot on the brake?
    greetings
  3. skateboardman
    skateboardman Road Train Member
    6,232
    5,706
    Jan 14, 2012
    flatbed heaven
    I would hold out for a window seat
    blairandgretchen, Pmracing and 123456 Thank this.
  4. vikingswen
    vikingswen Road Train Member
    1,436
    1,990
    Jun 14, 2012
    In the Stratosphere
    Your question does not make any sense in English. I assume your are German since you speak German in the movie. You need to figure out in which position the shifter comes to rest when in neutral when in the lower gears and the same when you push past the detent to go to the higher gears. That will let you know in which direction you should push the shifter when going for the next gear. Also since this might be a "Fahrschulenlastwagen" the shifter might have been abused more than normal and it can get a bit tricky.
    I think to remember the rest points being between 3 and 4 and than 5 and 6 in the upper gears from the Mercedes, ZF and MAN trucks I drove back in the 90s.
    In the US and Canada most transmissions are direct shift and are not fully synchronized.
    I hope this helps.
  5. blairandgretchen
    13,440
    72,483
    Dec 9, 2011
    South west Missouri
    Thread has been moved to "economy airline seating advice". :)
    HotH2o Thanks this.
  6. Pmracing
    Pmracing Road Train Member
    6,354
    3,178
    Jan 28, 2011
    Arlington Heights, IL
    I'll have a go at a comment.
    Downshifting to a stop, floating (no clutch) I brake with my left foot and control the throttle with right foot to match engine RPM to road speed and gear. At the last moment I use the clutch for full stop.
    Mikeeee
  7. peter_x
    peter_x Light Load Member
    89
    51
    Aug 24, 2013
    Isn't that uncomfortable with the shifter so far back?
    Also what is the air noise on every shift? I guess it is air assisted?
  8. Pmracing
    6,354
    3,178
    Jan 28, 2011
    I was also thinking that.
    Mikeeee
