Sigh...first major bill for owning used truck
Discussion in 'Ask An Owner Operator' started by engine_900, Oct 26, 2023.
  1. engine_900
    engine_900 Bobtail Member
    20
    22
    Jul 16, 2021
    Vancouver, BC
    2016 T680 isx15 13 speeds, I got it 2 years ago at 595k miles. Now right over 700k miles the tranny can't get into 3/4/7/8 gears, basically the whole right side.
    Shop quoting 14hrs labour, 4500 cad for 2y reman tranny. Total 6500 cad for tranny alone.
    There have been some suspicious oil leaking/spill around clutch brake, causing very difficult to get clutch brake working except when truck starting at morning (maybe oil spill to clutch when driving on highway). A good chance to take a look on this. Is that probably rear main seal?
    Any ways would you guys recommending replacing clutchs as well? looks like total gonna be 8000 cad (6000 USD) in total. Not that big but quite a major bill for the first time.
    austinmike and CruzControhl2 Thank this.
  3. Ridgeline
    22,400
    116,456
    learn how to drive the truck without a clutch brake.
    Likelyness it is the trans seal, but replace the rear main too and the clutch.
  4. roundhouse
    roundhouse Road Train Member
    3,169
    7,209
    Jul 11, 2018
    The whole side not working may be the shift rails .
    If the whole trans was bad wouldn’t it be every gear ?
    Rideandrepair and engine_900 Thank this.
  5. Last Call
    Last Call Road Train Member
    7,568
    45,902
    Mar 15, 2021
    To answer this part of your question there is no doubt I would not replace the clutch too you would be foolish not too
  6. Tug Toy
    Tug Toy Road Train Member
    6,973
    72,968
    Jul 4, 2015
    Corn field
    Usually they require you to put a new clutch in for the warranty to be valid?
    I know Eaton requires a new clutch and a very specific oil on the same bill.
  7. Rideandrepair
    17,337
    56,256
    Aug 8, 2015
    Absolutely replace clutch, get a good 2050 Eaton easy pedal. Should last 1 mil miles . Might as well do rear main seal. Only extra cost is removing flywheel, and that’s only if it doesn’t already need to be resurfaced. It will definitely start leaking, probably before 1 mil miles if it’s not already. Clutch brake not working isn’t because of oil. They’re made to operate with grease on them. Most likely likely it’s worn or linkage is worn or out of adjustment. As mentioned make sure the trans is actually bad, not just a linkage or something that can be fixed by removing the top.,when mine went bad, a friend pulled the inspection plate, could clearly see and move the upper set of gears. I think it’s called the right bank. It’s the highest gears in the trans. Maybe was ran with low oil? I don’t know much about transmissions. A good mechanic can probably tell you for sure.
    jbatmick, JoeyJunk, engine_900 and 4 others Thank this.
  8. blairandgretchen
    13,377
    71,914
    Dec 9, 2011
    South west Missouri
    Pull trans and have rebuilt by a reputable shop. Reman trans are gone through on assembly lines and by tolerance specs. A good shop will replace all parts necessary to see you another 800k miles down the road.
    Replace clutch, resurface flywheel - and while the trans is out, replace anything you think would be easier to do at that stage.
    That's just my 2c, NZ/CAD/USD or pesos.
  9. CruzControhl2
    CruzControhl2 Light Load Member
    123
    81
    Sep 24, 2023
    North America
    Don't own a truck yet but I see some really good mechanical advice. Where/who would resurface a truck flywheel..kenworth/machine shop?
    Also is there any throw out bearings he should replace?
  10. blairandgretchen
    13,377
    71,914
    Dec 9, 2011
    South west Missouri
    You'll be glad you found here then, after a bit of looking around.
    Back when I was company driver when I joined this forum - I went . . .
    "SSSSHHHHHHH - the big boys are talking" - and just read, and learned. And there's Sooo much to learn.
  11. engine_900
    20
    22
    Jul 16, 2021
    Vancouver, BC
    Thank you all for your great advice. I've heard tranny can last 1mil miles plus, while the truck has been running through mostly I-5 from BC to CA, also lots work within BC mountain. 80% time load 77-80k lbs. Tranny temp reached 220-230 when climbing hills in BC/OR/CA. During the summer it would almost reached 240... I suppose such usage and high tranny temp have shortened the lifespan?
