Single Axle Truck, power only, and axle vs cargo weight
Discussion in 'Questions From New Drivers' started by Shabadabado, Mar 15, 2022.
  1. Shabadabado
    Shabadabado Bobtail Member
    Mar 11, 2022
    Looking at doing Power Only with my Single Axle freightshaker. I know, I know, I need to get a twin screw, but it's just not in the cards right now, and I need to get to work.
    I know the rear axle rating is 20K. Weight with no trailer is a hair shy of 15K, if I remember correctly, with a bit over 5K on the rear axle. This leaves +/- 15K available on the rear axle.
    In my mind this means I can carry about about 30K, cargo and trailer combined. Am I understanding this right? I'm guessing it can be more or less, depending on what's loaded and its position on the trailer?
    I guess what I'm asking is if there's a way to calculate what the pin weight of a loaded trailer "should" be, for a given trailer and load.
    Also, on the load board when they give the weight for power only loads, generally speaking is that the cargo BOL, or the total including the trailer?
    Very newb questions, I know. I'm coming from the car-hauling world, where load weight was never really a concern for this rig.
    blairandgretchen Thanks this.
  3. Chieftains
    Chieftains Medium Load Member
    362
    896
    Jul 18, 2021
    Weight on loadboard is always Weight of the product. So factor in trailer weight
    tscottme and blairandgretchen Thank this.
  4. blairandgretchen
    13,376
    71,892
    Dec 9, 2011
    South west Missouri
    Brokers tend to ignorantly and generically list weight as 40,000 lbs - when you call it may be 10-20k or 90k.
  5. tscottme
    tscottme Road Train Member
    BOL weight is usually freight only.
    BROKERS LIE ABOUT EVERYTHING. What are you going to do if the broker "underestimates" the weight and you already are hooked to it?. Getting some more money for that load may not fix "your problem".
  6. prostartom
    prostartom Light Load Member
    216
    465
    Jun 20, 2014
    Single axle tractors pull for Amazon Relay all the time. I did it for 7 weeks, most of the loads are less than 10k lbs.
    My tractor is 15,500 lbs full of fuel and DEF, and I weighed an empty 53' Amazon trailer at roughly 15,000 lbs. My tractor is only registered at 54k lbs so that left me with about 23k lbs payload, plenty for 95% of Amazon loads.
    Your tractor is probably registered higher so that would give you a higher payload, but it will be easy to overload your rear axle.
    But beware, you can still get heavier loads from Amazon. During the last week of February I was getting a heavy load pretty much every night, lucky for me, they weren't going too far and they didn't put me over any of my axle weights, just gross weight.
    My tractor has a 23k lb rear axle capacity and it has a rear suspension pressure gauge so that helped estimate how heavy I was on the rear axle. Most loads bounced around 30 - 40 psi, heavier loads were 50 - 60 psi. 70 psi was getting into the danger zone and 80psi, just say no. I failed to do that on a load coming out of Hazelton PA that weighed way too much and it ended up costing my company $2800 for an overweight ticket. Luckily they like me.
    But like other posters said you can't trust the BOL weights. If it feels heavy you better weigh it. I did do 1 live load for them, the BOL said 15k lbs but after they loaded me my suspension guage was reading around 70 psi, so I was thinking no way is that load only 15k. When I looked in the back of the trailer it was only 13 pallets and they loaded it all the way to the front. I went ahead and got it weighed and my rear axle was right at 19,900 lbs, but I was only 46,600 gross, so in this case the Bol was accurate.
    Another option is JB Hunt 360. I looked into them in case Amazon took a huge dive. Where I am in the Mid-Atlantic there were plenty of loads listed under 16k lbs and power only. They also let you search by load weight. I didn't get any farther than that with them as my company was pretty happy with Amazon so we stuck with them.
  7. bowlwinkle
    bowlwinkle Heavy Load Member
    824
    704
    Aug 27, 2008
    Ankeny, IA
    Maybe check with a Fed Ex contractor. I see them with single axles a lot
  8. WiggleWagon
    WiggleWagon Light Load Member
    232
    312
    Aug 17, 2016
    Parked At The Fuel Island
    Look in to dry bulk haulers in your area. The ones in my area hire owner operators and you pull their double pneumatic tankers.
