small cb ugrade?
Discussion in 'CB Radio Forum' started by Red Wide Glide, Nov 24, 2014.
  1. Red Wide Glide
    Red Wide Glide Bobtail Member
    48
    26
    Aug 22, 2014
    my company truck is a freightliner columbia glider package with cobra 29 and dual mirror mounted antennas. my only issue is that when i pass another one of our drivers we only have about 30 seconds max to exchange info before we're too far away. i'd like to get a bigger window to communicate but im not looking to be one of those guys you can hear from another country.
    from what i understand the radio is fine and could just be taken in to a shop to be tuned and the thing i should worry about is the antennas and wiring. realistically what would i be looking to spend to buy better antenas and wiring and have it all hooked up?
  3. Tall Mike
    Tall Mike Road Train Member
    7,500
    35,495
    Aug 20, 2014
    The Hammer Lane
    If it were me I'd upgrade the antennas and set the SWR's first, then see if your happy..
    Wilsons are a decent antenna and aren't priced too bad..
    I had a similar problem with a 660, I got rid of the KW stock antennas and put on some Wilson 2000's, tuned them with my analyzer, then added my Stryker 480HP radio...Head and shoulders better than the stock KW setup.
  4. blairandgretchen
    13,691
    74,463
    Dec 9, 2011
    South west Missouri
    Run a separate co ax out to a bird perch mounted antenna.
    Don't matter what - just get off the factory setup.
    mike5511 Thanks this.
  5. Tall Mike
    7,500
    35,495
    Aug 20, 2014
    The Hammer Lane
    excellent point..
  6. Red Wide Glide
    48
    26
    Aug 22, 2014
    sorry if this sounds stupid, im kind of clueless but doesnt that require drilling into the cab of the truck to mount the bird perch? i dont think they would let me do that.
    i take it that it would be allot more costly to just have them rewire the stock setup with better components?
  7. brian991219
    brian991219 Road Train Member
    3,003
    6,117
    Aug 10, 2013
    Lords Valley, PA
    The antenna bracket will clamp around your mirror arms on the Columbia, most guys just run the coax cable thru the weather stripping around the door, it wears it out at that point but it doesn't require drilling holes. To replace the coax and route it thru the doors and such is a much neater installation but is not worth it on a company truck, a simple cable out the door will still improve the signal output over the factory wiring. The factory wiring is shared with the AM/FM radio and goes thru a signal splitter plus it has several connections in it where signal loss and noise are introduced. A basic Wilson 2000 or similar antenna with a mirror mount and good coax should not set you back more than $75, with good cable. Get the antenna tuned when it is installed and you should see a dramatic improvement over the factory setup.
    Stay away from the "golden screwdriver" peak and tune jobs from the cb shops, most of them will not do anything to increase output and only mess up the radio, not something you want to do. Search for the thread Peak and tune myths on this site, it is a good source of information.
  8. Red Wide Glide
    48
    26
    Aug 22, 2014
    few more questions if you dont mind...
    1.is there any reason to go with single vs double antenna?
    2. does it matter where i put the new antennas in relation to the 2 that are already there?
    3. could it really be as simple as screwing 2 wilsons into the spots where the antennas are now and running new coax from those mounts through the doors into the overhead and down into the little built in cutout for the radio?
  9. icsheeple
    icsheeple Trailing the Herd
    2,548
    2,552
    Nov 1, 2013
    Kansas City, KS
    From what I've read a single good quality antenna with a single coax will be all you need. Peaking and tuning just adds distortion.
  10. brian991219
    3,003
    6,117
    Aug 10, 2013
    Lords Valley, PA
    Single antenna will be fine, and yes you can use the existing mounts and run new coax. This will be better than leaving the existing antenna on the driver mirror and mounting the new one next to it. Leave the factory antenna on the right side mirror so your AM/Fm radio will still work, Freightliner uses the cb antenna for the music radio reception as well as the cb, that is why they are so bad as cb antennas.
