So what happens to a load when it gets too warm?
Discussion in 'Refrigerated Trucking Forum' started by Gunner75, Jul 2, 2014.
  1. Gunner75
    Gunner75 Road Train Member
    5,701
    9,075
    Mar 17, 2014
    Jackson Center Ohio
    When I was researching my choices on companies, I come across a few reefer haulers that interested me, when I explained to my dad what it was they hauled, he said to avoid reefers as much as possible. For asking why, he said because a lot of companies will stick you with the freight if it goes bad, or gets to hot and is rejected by the receiver. So I ask you, what happens if the reefer you are hauling stops running and your temps get to high, or the load goes bad?
  3. joseph1135
    joseph1135 Papa Murphy
    11,340
    27,301
    Nov 8, 2009
    The Highway To Hell.
    I've been pulling reefers for 8 years. These aren't the reefers of yesteryear. They're dependable and most companies monitor them. And if the load is bad or rejected, it gets sent somewhere else. I've never had a load's problems put on me in the last 8 years.
  4. Balakov100
    Balakov100 Road Train Member
    3,938
    2,641
    May 10, 2012
    Temple, TX
    Even if a load goes bad.
    #### happens and most respectable companies won't put that on you...unless it's clearly your fault
    Guess you would still be stuck with it until the company finds some other place for you to take it..
    I have not had any problems myself.
    Even though I worked for a company with a bunch of junk equipment.
  5. Chinatown
    Chinatown Road Train Member
    76,666
    178,373
    Aug 28, 2011
    Henderson, NV & Orient
    I never had a load go bad and I pulled some older model reefers. A couple times the thing didn't want to start when on cycle mode, so I put it on continuous mode until the load was delivered. I've seen warm or supposedly warm loads get resold by the broker at a discount. Some 0/0's can really get burned with something like that, especially if the receiver is a crook.
    The driver should monitor the temps anyway and the slightest problem, get to a shop and get it fixed ASAP.
    I actually liked pulling reefers coast to coast.
  6. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    I pulled a reefer 6 years and never lost a load to temperature. I had 3 claims I remember. One for a box of leaking chicken juice over 7 other boxes. Not charged and it went to a food bank. Second claim was for two damaged boxes of beef thrown on the edge of the last pallet. Hard to secure when the load was sealed. Tyson ate that one. Third one was obvious forks jabbed through. Shipper ate that one too as I watched the unload.
    Produce, I batted a 1000. My favorite was sitting on a load of bananas over a weekend in subzero temperatures. My load was accepted while the other two trucks got rejected. Bad for the company but it made me feel good. :)
    If you want to go then go. Reefer is fun and if you CYA you won't have any problems. Pulp all loads you can before during and after and document. Also carry a good camera with you.
    Expect to do a lot of night driving with meat, but that too is enjoyable. Produce is more flexible on the hours.
    I too liked coast to coast. Well almost, LA/Atlanta areas. :)
    mlefler Thanks this.
  7. bubbavirus
    bubbavirus Medium Load Member
    Once saw, actually smelled an area near a dumpster where someone got rid of a load of fish.
    Must be what those beached whales can do.
  8. 201
    201 Road Train Member
    12,621
    25,905
    Apr 16, 2014
    high plains colorado
    One of the several downsides to reefer hauling. One of the best gizmo's I've seen, are those digital temp. readout devices that can be seen in the truck mirror. If the load can't be resold to like a dog food company (don't ask what goes into THAT stuff), or some non-food consumption place, we have landfills in Wis. that are getting so tall, they're going to have snow on them in July, I've seen reefers dumping their load in those.:tongue6:
  9. Emulsified
    Emulsified Road Train Member
    3,663
    3,499
    May 6, 2010
    Dallas, TX
    If you learn to haul temperature control properly, there is almost no chance of a spoiled load.
    You may have a couple rejected cartons due to being crushed, or forklift damage, etc like another poster said, but if you monitor your temps, secure your load, MAKE SURE YOU HAVE FUEL IN THE TANK!, and aren't delayed too long (produce has a very short shelf life), you will not have problems.
    Most loads rejected are from the large grocery companies...they over bought. They'll reject a load saying it's warm, bruised, cold or the wrong size...just because they had anticipated selling more of that product in the 7-10 days since they placed the order you are now trying to deliver.
    Those loads go to brokers, don't usually involve the driver (except to take them there) and are off your truck in hours.
  10. pattyj
    pattyj Road Train Member
    22,474
    20,137
    Jul 19, 2008
    Sioux City,ia
    I have never had any trouble.But it is very important to check and double check your bills and make sure the reefer is set to whatever temp the bill says and of course check your reefer every time you stop..A few drivers at kb got fired for bad loads because they had the reefer set too high and the entire load had to be tossed.
  11. ‘Olhand
    ‘Olhand Cantankerous Crusty
    6,750
    16,653
    Jan 18, 2011
    Patty--reminds me of the(well ill leave co.name out) driver who rolled into Wegmans in PA last year w/frozen load of fresh Sweet Corn.....told receiver--well that put ICE on it to help it get cold so I thought it was to freeze it....had the unit set at -10.......
    I held my tongue.....i swear...really I did.....
    To the OP....ALWAYS know what you are hauling&what the proper setting is...then just keep your eye on it & you'll be fine.....
