Speedometer inop/fluctuates
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by JHaulingS, Nov 24, 2017.
  1. JHaulingS
    JHaulingS Bobtail Member
    47
    Jun 4, 2014
    I have a 06 FL Columbia with a Detroit Series 60 & Eaton Fuller Auto Shift Tranny. After about 30 min of driving, the speedometer starts to fluctuate during up shifting. It starts to drop down just before it shifts to the next higher gear, then comes back up to indicate the current speed after shifting into that next higher gear. The speedometer is steady & works normal as long as its not up shifting. Often after I've driven the truck for several hours, stop, turn the eng off, then if I start it soon afterwards, the speedometer won't work at all when I start driving. The needle just sits on the bottom. Since its an auto shift, shifting is very difficult under both these conditions. If the eng is off for several hours or overnight, when I start it up & start driving, everything works fine, for about 30 min. I'm also getting an ECU 128 fault, an ABS 136 fault, & check eng light. Sometimes the check eng light will go out while driving, but usually always comes back on a few seconds or mins later. I'm thinking the speedometer circuitry inside the ECU is failing. Just wondering if anyone else has experience this problem. And also, when the speedometer needle just sits on the bottom, the odometer doesn't advance, nor does cruise control engage.
  3. scottied67
    scottied67 Road Train Member
    10,826
    12,673
    Mar 14, 2010
    california norte
    My 13 speed will show 30-35 miles per hour on the 'splits' or low side. I was just using my GPS mileage for the IFTA reports and let the truck track fewer miles than reality- better for resale value later.... lol But I heard there is a speedo/odo wire coming from the transmission that might need replacing.
  4. Hammer166
    7,572
    27,590
    Aug 18, 2007
    ~8600+' and loving it!
    The speed sensor itself could be your issue. It's the quickest, easiest fix, and your symptoms point that way. On that old of truck, a tailshaft bearing getting loose could also cause this by allowing the tone ring to move away from the sensor.
    Remy73 and Old Man Thank this.
  5. Goodysnap
    Goodysnap Road Train Member
    3,748
    9,115
    Jul 12, 2017
    Look for evidence of rust around the trans output yoke nut. If the yoke is loose the tone ring for the sensor can spin on the output shaft and cause the speedo to drop out or read lower than normal. A crude method of checking the wiring is to get a new sensor and plug in to the existing wiring connection at the VSS in the tail-housing. These are cheap like 40 bucks. Lightly and rapidly tap the sensor on any metal object under the truck. Have a partner watch the speedometer with the ignition on the speedo should bounce while tapping the sensor. It will only hit maybe 5-10mph. If no bounce, you likely have a wiring issue somewhere. If you have good signal you indeed likely have a bad Vehicle Speed Sensor. Be prepared to replace the trans output seal when changing the sensor. They get rust jacked inside and the housing will need to be removed to grind out the old sensor and the rust buildup.
    Hammer166 Thanks this.
