Split break question
Discussion in 'Questions From New Drivers' started by LovemyGPS, Dec 20, 2010.
  1. LovemyGPS
    LovemyGPS Bobtail Member
    39
    Jun 28, 2010
    Connecticut
    Can you begin a split break by taking a 2 hour break, or should the 8 hour portion of your split break be taken first?
  3. lil may
    lil may Road Train Member
    1,302
    702
    May 25, 2009
    Read all Log post by LogsRUs I think she explains it very well
    rocknroll nik Thanks this.
  4. Bumpy
    Bumpy Road Train Member
    6,529
    5,257
    Jan 27, 2009
    New Ulm,MN
    Good Luck figuring all the ins & outs on that one. Its easy to make a mistake using it.(at least for me):biggrin_2552:
  5. leanright
    leanright Medium Load Member
    359
    119
    Oct 12, 2010
    phila,pa.
    I was told by my company that you have to take 8 first. I don't use the split myself so I'm not keen on the issue.
  6. G/MAN
    G/MAN Road Train Member
    7,031
    8,622
    Sep 3, 2010
    I don't recall there being a rule about whether you need to take the 8 or 2 first. You just need to be careful to not go over your 11 total driving time before taking your entire 10 hour break. I do split sleeper berth sometimes and sometimes use the 2 hour break first. I have never had a problem doing this when my logs have been checked. I am very mindful of not going over my legal driving time before taking the entire 10 hour break.
  7. scottied67
    scottied67 Road Train Member
    10,826
    12,670
    Mar 14, 2010
    california norte
    Doesn't matter if you use the 2 or 8 first. It's *easier* to use the 2 first (split your 11 hours driving time around a 2 hour break during your 14). Then you only need 8 hours in the sleeper to finish the 10. But you have to add up your hours since after the 2 hour break, subtract from 11 and that's the max you can drive before taking a 2 hour again.
    8 hours first, split driving time, take 8 hours off in sleeper. Go to end of your original 14 hour break- count over 8 hours now that's the end of your 14 now. Just be careful, double check everything to ensure you don't go over 11, don't go over 14 of course don't go over 70.
  8. rocknroll nik
    rocknroll nik High Risk Load Member
    4,490
    5,770
    Oct 18, 2008
    can't read the sign
    The problem I have always seen with split breaking as it is now ...is that it's harder to get back to a normal cycle and that even most logs departments don't understand how to split properly.
    The way I look at it is if I have to take 8 hours off anyway why not go the full 10 in one shot and not worry about it. but each situation is different and no two drivers are alike in that respect.
  9. scottied67
    10,826
    12,670
    Mar 14, 2010
    california norte
    Comes in handy sometimes like this scenario:
    Drove about 4 hours to consignee to finish this load at 0900, emptied out about 1000. Got a preplan to go pickup next load at 1800. Might as well put that 8 hours to good use otherwise my 14 was going to end at 1900 anyway. By splitting it, I was able to knock off about 7 hours driving by after midnight and take 2 more hours and hit it again for 4 more. At that time I can take 8 or 10 off now. It's a great time management tool.
  10. rocknroll nik
    4,490
    5,770
    Oct 18, 2008
    can't read the sign
    Agreed there were times I used it also when I drove for Celadon but after getting on with a smaller company it made no sense for me to use it anymore.
    But yes you are correct that there are times
  11. 123456
    123456 Road Train Member
    10,555
    5,747
    Oct 22, 2010
    32179
    It's a shame they don't have anything like this available !!
