Werner had etrainer on split breaks that confused the hell out of me and I thought you had to take a 10 sleeper/off to get 14 back. So can you do that 8 sleeper and 2 off/sleeper or whatever it was?
Split breaks legal?
Discussion in 'Questions From New Drivers' started by aramil248, Mar 10, 2018.
Page 1 of 5
I ain't got a clue... Punch it in your ELD and see if it works.
joesmoothdog and nax Thank this. -
Specifically, drivers of property-carrying commercial motor vehicles may accumulate the equivalent of 10 consecutive hours off duty by taking two periods of rest, provided that:
- One of the periods is at least 8 consecutive hours in a sleeper berth;
- The remaining 2 hours (taken either before or after the 8-hour period) is spent either off duty, in a sleeper berth, or any combination of the two;
- Driving time in the period immediately before and after each rest period, when added together, does not exceed 11 hours; and
- Compliance with the 14-hour rule is calculated from the end of the first of the two qualifying rest periods.
Drivers of passenger-carrying vehicles may split their required 8-hour rest period into two separate periods, provided that:
- The two rest periods are spent entirely in a sleeper berth;
- Neither period is less than 2 hours;
- Driving time in the period immediately before and after each rest period, when added together, does not exceed 10 hours; and
- The on-duty time in the period immediately before and after each rest period, when added together, does not include any driving after the 15th hour.
tinytim, DSK333 and Justrucking2 Thank this. -
Yes split break provision is perfectly legal, I use it all the time.
Of course it's legal. Whether your carrier allows you to use it or not is a different story though.
tscottme Thanks this. -
The split sleep is legal but I only recommend using it if you know for sure you're going to park for 10 hrs once you get to your destination. I use it if I'm trying to get home. I believe if you park for 8, why not just go ahead and get the ten
Yes, split-sleeper is legal.
You don't get 14 back when doing a split. You only get the hours of your 11/14 that were unused prior to whichever part of your 8/2 split you did before this one. In simple terms, when your sleeper berth is split; so is your 11/14 until you take a full 10 (or reset).Last edited: Mar 10, 2018
Reason for edit: Bee forehomeskillet, Farmerbob1 and jammer910Z Thank this. -
Lepton1, Farmerbob1, Brickwall and 1 other person Thank this.
Just keep in mind that while lefal, qualcomm doesn't allow 2/8 split, only 8/2. It's just not in the programming. So don't take a 2 hr break thinking it'll do anything for you unless you did 8 in the sleeper already.
Justrucking2 Thanks this. -
Brickwall Thanks this.
Page 1 of 5
