Spread Axle Jumping when making a turn?
Discussion in 'Ask An Owner Operator' started by RTR, Jul 20, 2015.
  1. RTR
    RTR Light Load Member
    194
    49
    Alabama
    2011 Bigger Bubba Reitnouer Trailer Spread Axle. In the past week, whenever I make a 90 degree turn, my trailer seems to be hopping on the back axle. I thought maybe my dump valve was not working, or it was super slow to dump, so checked both of them, they are fine.
    Have not changed anything or done anything different, need help figuring this out?
    Any advice and or suggestions would be greatly appreciated.
  3. 315wheelbase
    315wheelbase Heavy Load Member
    783
    601
    Oct 26, 2014
    too much weight on the tire to do a 90 degree turn,,,very simle make wider turns and go very slow
  4. RTR
    194
    49
    Alabama
    It also seems to be doing this when empty
  5. AModelCat
    159,914
    Check your suspension out. Loose parts and worn bushings can do some funky stuff sometimes.
  6. baha
    baha Road Train Member
    4,137
    2,836
    Jul 25, 2013
    ga
    Take off the shocks to see if they have any gas left in them?
  7. mtoo
    mtoo Road Train Member
    1,935
    4,500
    Jan 15, 2011
    Retired on bended knee
    It's a spread doing a 90 degree turn. thats what they do. A lot of things can effect if you feel it. asphalt, concrete, humidity, weight, how hot it is, how cold it is. I think a bigger bubba would do it more than my big bubba..
    Those 90 degree turns are hard on equipment.
  8. blairandgretchen
    13,388
    72,036
    Dec 9, 2011
    South west Missouri
    Is there a mechanism that equalises pressure that is faulty ?
  9. KenworthGuyNH
    KenworthGuyNH Road Train Member
    1,050
    2,686
    Dec 11, 2011
    Central, NH
    The OP knows about dump valves..............pretty safe to say he has the good sense to avoid 90s when possible. Your "very simple" solution does not translate to the world the rest of us operate in. Every now and then a 90 is unavoidable; you just can't say "don't do them".
  10. KenworthGuyNH
    1,050
    2,686
    Dec 11, 2011
    Central, NH
    It's been pretty hot this week. Have you noticed this more when just coming off the highway with hot tires? Or in all temp/time situations?
