starter staying engaged 98volvo wg64 w/m11 cummings, on 6th starter
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by chabotco, Apr 27, 2021.
  1. chabotco
    chabotco Bobtail Member
    what would cause starter to stay engaged, been through 6 starters, help. what the power block on the rear of engine? Thanks
  3. Judge
    86,231
    Could be something as simple as a bad alternator, if it doesn’t get proper charge it can make it stick, have had that happen, as crazy as it sounds.
    If it’s only throwing 12.5 not 13.5-14.
    It was on a C15 cat engine, but it can happen
  4. Mike250rs
    Mike250rs Heavy Load Member
    881
    7,079
    Sep 24, 2019
    Raleigh, NC
    When was the last time the ignition switch was replaced?
  5. xsetra
    xsetra Road Train Member
    5,104
    6,967
    Aug 21, 2011
  6. Smellfunny
    Smellfunny Road Train Member
    1,445
    967
    Jan 28, 2012
    South Carolina
    One thing that could be possible is if the starter came with a spacer plate and someone left it off. You could check with Volvo and see if it came with one originally and if it has one now. Cummins sometimes has this plate and without it the starter drive may be going in to far and getting hung.
  7. BoxCarKidd
    BoxCarKidd Road Train Member
    4,435
    6,471
    Aug 26, 2014
    Some of those trucks had a starter control relay in the wiring harness on the left side of the engine.It was toward the rear and about have way up the block as beast I recall. Looks more like a big fuse holder.
    Power went from the starter button to this relay. Then this relay connected power from a larger supply to the starter relay. They were bad to stick and smoke starters. You can just replace it as original but I would up grade it to a forklift type solenoid or something. Mount it on the firewall and run a little bit of wire.
    spsauerland Thanks this.
  8. mile marker 27
    mile marker 27 Road Train Member
    1,229
    1,635
    Dec 4, 2019
    Low voltage, bad ring gear, ignition? Can’t imagine it being the starter every time, you said it’s the 6th one, right?
  9. BigNutTurner
    BigNutTurner Bobtail Member
    Did the past starter failures end up with the starter staying engaged?
