Steam cleaning the under carriage?
Discussion in 'Ask An Owner Operator' started by JonJon78, Sep 3, 2018.
  1. JonJon78
    JonJon78 Road Train Member
    7,215
    42,475
    Jul 1, 2018
    Has anyone ever steam cleaned the under carriage of your truck and up around the frame etc etc? I was greasing my truck today and started thinking of ways to clean up all the old grease that is caked onto everything... Some of it is just road grime not necessarily grease.
    Or does any company offer some type of service that takes care of this issue?
    The under carriage wash that you get at blue beacon certainly doesnt take care of this, about the only thing that's good for is salt.
    Oldironfan Thanks this.
  3. Oldironfan
    Oldironfan Road Train Member
    5,776
    5,544
    May 22, 2017
    Reefer shops steam clean reefer engines.
    Mike2633 and JonJon78 Thank this.
  4. Klleetrucking
    Klleetrucking Medium Load Member
    378
    346
    Dec 11, 2010
    S.C.
    FWIW, I did mine myself at least once a year with Gunk Concentrate and a 2300 psi pressure washer. Pulled the steer onto 8" blocks, put on a "moonsuit", got on the creeper. It's a nasty,nasty job.
    There at one time was a place near Ft. Wayne that did it. S & J Truck sales did a lot of frame stretches and sent the truck there prior to doing any work.
    blairandgretchen and JonJon78 Thank this.
  5. Mike2633
    Mike2633 Road Train Member
    6,461
    25,990
    Jun 14, 2013
    At Home on The West Side
    You could call a carpet cleaning company company that advertises truck mounted steam cleaning. Have them shoot some Chemeisters Grease Eraser on that stuff and then high pressure rinse it. If I still had my truck mount, I would hose it down and clean it off for you.
    JonJon78 Thanks this.
  6. JonJon78
    7,215
    42,475
    Jul 1, 2018
    I'm not far from Ft. Wayne so I pass through that area frequently. Any idea of what the place was called? I figured it would be a nasty job, I wouldn't mind paying for it versus doing it myself.
    Mike2633 Thanks this.
  7. Klleetrucking
    378
    346
    Dec 11, 2010
    S.C.
    Call S&J Truck Sales. They're the guys that stretched my frame. They should be able to put you in contact with the steam cleaner outfit.
    Might be a wild goose chase as this was back 10 yrs. ago. BOL
  8. sawmill
    sawmill Road Train Member
    3,795
    70,174
    May 29, 2015
    Evanston, WY
    I have a set of ramps for my stepdeck and can do mine as often as I feel like it. Usually twice a year. I just set up the ramps as tall as they go and drive the steer tires right up to the top. Fire up the Hotsy and get to work. I can get most of it clean without even getting all the way under the truck.
    I think it was @Lepton1 that knows a place in OKC that will do it for you for under $200.
    Tug Toy, Lepton1 and JonJon78 Thank this.
  9. Ridgeline
    22,636
    120,607
    I do on some of the trucks, I have a guy come in to use my Hotsy pressure washer in Indiana and have one here to do the trucks in the yard.
    Tug Toy and JonJon78 Thank this.
  10. blairandgretchen
    13,659
    74,334
    Dec 9, 2011
    South west Missouri
    I’ve got a commercial grade hot water setup that will do it.
    Flex wand is key, and as said - expect to trash a set of clothes doing it. NASTY.
    I do it about twice a year.
    The mechanic shop loves me for it.
    Mike2633, Tug Toy, JoeyJunk and 2 others Thank this.
  11. Lepton1
    Lepton1 Road Train Member
    12,647
    25,589
    Nov 23, 2012
    Yukon, OK
    OKC Truck Detail @ 5720 SW 11th Street. Make an appointment, they are busy. Weekdays only. I've used them three times in the last two years, as I buttoned up my engine. Money well spent.
    sawmill, Tug Toy and JonJon78 Thank this.
