Is there a reason why going from a van to a flatbed would change my steer axle weight? I'm not really over enough to worry about it, but I don't understand the reason behind it.
Van Load 1/scale 1
Gross 78000, steer 11540, drives 34320, tandems 32140
Van Load 2/scale 2 (slid 5th wheel)
Gross 77780, steer 12000, drive 33180, tandems 32600
Flatbed Load 1/scale 1
Gross 76740, steer 1220, drives 32600, tandems 31920
I know if I want to fix it slide it back one hole. Anyway, just curious if someone can educate me a 'lil. Thanks!!
Steer axle weight different trailers?
Discussion in 'Questions From New Drivers' started by DDlighttruck, Jan 27, 2016.
Assuming identical 5th wheel position
Fuel? Driver on/off? Passenger?
The flatbed notes you provide tell me you need to move your 5th wheel back some (maybe one hole) because if you ever put 34k on the drives you're going to be kind of heavy on the steer. Get to a point where 34k on the drives, full fuel and you're between 12k and 12.5k steer. and leave it alone. Van, flatbed, makes no difference once you've found the sweet spot, LEAVE IT ALONE!Last edited: Jan 27, 2016
Longarm, White_Knuckle_Newbie and DDlighttruck Thank this. -
I'm guessing the steer was around 12,200?
That is still a good weight. They won't pull you in for a couple hundred over on the steer, and I have had it like that for years.
My current steer weight is 12,240.
It could be a little extra weight on the trailer front end or more fuel in the tanks.
My guess would be fuel.
Either that or you have a really fat person in the passenger seat.DDlighttruck Thanks this. -
so, there is no real weight difference between a empty flat bed trailer and a dry van trailer?
I'll have to doublecheck on scale 2 if I fueled up that day on my logs. That was the first thing I considered. It was 6-8 weeks ago, I don't carry on the truck that far back.
I know for a fact scale 1 and 3 were fill tanks and go over to the scale.
@STexan, driver on all 3 times. I wondered if the flatbed "hooked" deeper on the 5th wheel, moving weight forward. Yes, I agree, I thought I had it set where it should be, and was going to leave it there. I'm still not worried about the overage, I'm just trying to understand it. -
Extra tools, chains and straps in the cab when pulling the flatbed?
I think the center of gravity will always effect weight distribution. It seems to me to be basic physics.
Ultra light VAN or aluminium flat maybe a steel all have different weights. If your tires and axel can handle 12200 just roll on driver.
Too many variables to not expect different steer weight results.
Mikeeee -
As long as you're not exceeding the load limit on your steers, don't fuss too much.
