Steer tires wear rapidly on shoulder
Discussion in 'Ask An Owner Operator' started by Kshaw0960, Oct 8, 2022.
  1. Kshaw0960
    Kshaw0960 Road Train Member
    1,581
    5,023
    Jun 17, 2018
    I have replaced the steering box (had a leak), tie rod ends, drag link, both king pins, bushings, new shocks, new centramatics, brand new Bridgestones m213 (their new one forgot exact name) and lastly an alignment. I even replaced all 3 knuckle joints on steering shaft. 15k miles later both shoulders on both tires are down 3mm on last half inch. This is the second set I’ve burned through. Don’t know what else to do.
    blairandgretchen Thanks this.
  3. Concorde
    Concorde Road Train Member
    4,722
    16,865
    Jun 29, 2016
    West Melbourne Florida
    Your alignment, was it done at a reputable shop? If it was done like at a TA I would try somewhere else.
    Tire pressure is something I’d look into also. Are they set to door jamb recommend pressure? Do you run a lot of heavy loads..perhaps increasing pressure would help.
    Siinman Thanks this.
  4. ProfessionalNoticer
    2,941
    7,858
    Apr 25, 2021
    Alignment issue. Sounds like the toe is out.
  5. Kshaw0960
    1,581
    5,023
    Jun 17, 2018
    Alignment is done by a big Michelin shop and they do my other trucks great. Tires at 105 psi and are 11r24.5 and I actually only run about 11,300 on steers. I don’t haul heavy.
    Only thing I can think of is the drive axles are a little worn on the tires and could be replaced soon and with an alignment. But would it be possible the drive axles can mess up the steers?
    Vampire Thanks this.
  6. blairandgretchen
    13,379
    71,943
    Dec 9, 2011
    South west Missouri
    All I can suggest is to take it to Chad at MD alignment in Kansas City. He’ll inspect first and won’t align until the mechanical cause(s) are addressed first. Let me know if you need his number, but you’ll find him on a Goog search.
    bzinger, Siinman and Vampire Thank this.
  7. Big Road Skateboard
    6,234
    34,321
    May 2, 2021
    Has this truck been wrecked? Bent axle?
    AModelCat and Vampire Thank this.
  8. SmallPackage
    5,475
    17,418
    Dec 20, 2019
    Marion Texas
    This has been an issue with that tire line. They are not testing very well. Mic and Bri have had to change compounding mixes due to epa bs. This effects all made in north america.
    Stupid stuff like certain chemicals in the tire dust from wearing rubber building up on roadsides and getting into ground water or causing cancer. China and other off shore tires are exempt tho so we are still ok.
  9. blairandgretchen
    13,379
    71,943
    Dec 9, 2011
    South west Missouri
    Good to know - thanks.
  10. bad-luck
    bad-luck Road Train Member
    3,300
    6,064
    Nov 16, 2013
    Baltimore, Maryland
    Did you get a 3 axle alignment?
    MartinFromBC Thanks this.
  11. pavrom
    pavrom Road Train Member
    3,185
    7,305
    Apr 29, 2012
    NE illinois
    Drive axles can mess up steers if not aligned ... Been there
    TallJoe and MartinFromBC Thank this.
