Carry 2 foot by 3 foot mats to place under drive tires......try to rock out in 5th gear, not granny gear.....carry 40 inch piece of chain to wrap around drive tire, thread thru spokes.....any other thoughts?
stuck on ice, best way to get going
Discussion in 'Experienced Truckers' Advice' started by bandit74, Oct 17, 2015.
Page 1 of 4
I carry a bucket of rock salt and a shovel in the winter.
Those mats will be spit right out if the tire even grabs at all.KB3MMX, demi, Big Don and 1 other person Thank this. -
Kitty litter.
Also if you're parking on ice don't forget to rock your truck once an hour or so. Keeps you from freezing to the spot.Straight Stacks, Ougigoug and Big Don Thank this. -
Don't get stuck?
G.Anthony, Straight Stacks, 77smartin and 1 other person Thank this. -
miss elvee Thanks this.
Wait until spring
I keep chicken grit with me. Doesn't absorb moisture like kitty litter will.
Dump some grit in front of the drives and put carpet squares on top of the grit. It will usually suck the carpet under the tire along with some grit. It's got me out a few times.bandit74 Thanks this. -
MJ1657 Thanks this.
Throw your Iron.
dca and lots of character Thank this.
Page 1 of 4
