T2000 N14 Cummins no start.
Discussion in 'Kenworth Forum' started by blairandgretchen, Apr 29, 2015.
  1. blairandgretchen
    13,377
    71,914
    Dec 9, 2011
    South west Missouri
    Truck has done this periodically since I bought it, now she won't start.
    All dash lights are working fine, but at key turn, I hear a click - and no crank.
    Any ideas on where to start looking?
  3. blairandgretchen
    13,377
    71,914
    Dec 9, 2011
    South west Missouri
    Grrrr. I post this - tap on starter with wrench, click, click . . Vroom!
    Something needs attention, I'm sure of that.
  4. QUALITYTRUCK
    1,809
    1,769
    Jun 14, 2009
    romulus,mi
    You just saved yourself diagnosis fee! Time for a new starter.
    blairandgretchen Thanks this.
  5. crzyjarmans
    crzyjarmans Road Train Member
    3,314
    2,441
    Jun 9, 2010
    Home
    Yep, if you can tap the starter and it starts? Then there you go!
    plus changing a starter isn't that hard, a couple wires, and bolts, anyone with a IQ of 80 can changes a starter, as long as you have some basic tools
  6. wore out
    wore out Numbered Classic
    15,924
    192,699
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Not trying to scare blairandgretchen, but if the bolts gall up coming out whoo what a chore. Naturally unhook ground cables first. Unhook grounds on starter zip tie them thru the hole, same with hots. Keeps them togather you be surprised how going back things can look freaky lol. 5/8 shallow well 12 pt socket and really good extension and long handle ratchet with a 3/4 and a 3/8 is all you need.
    We we have had trouble doing the same thing with reman Delco's right out of the box lately. So we been going back new or gear reduction.
  7. spindrift
    spindrift Road Train Member
    3,233
    12,905
    Dec 2, 2014
    Texas
    What wore out said. Starter bolts are steel and the housing is aluminum. If the bolts start to tighten up on the way out...STOP!! Better yet, just to be safe, hit the bolts with penetrating oil and let them sit over night. If you strip those aluminum threads, you're looking at a heli coil for sure.
  8. Ringo1
    Ringo1 Light Load Member
    89
    131
    Apr 20, 2014
    South Carolina
    Blair, last thing is place the old and new starter side by side to be sure the nosecone setting is the same. They generally are but that cone is adjustable and it can be clocked to fit your application.
    wore out and blairandgretchen Thank this.
  9. BoxCarKidd
    BoxCarKidd Road Train Member
    4,470
    6,507
    Aug 26, 2014
    Blair: I would check for open circuits ( bad connections) first on all terminals on starter, or at least tighten all connections. Unhook battery neg. first. Wore Out: What brand are those gear reductions you like and they interchange with a 42MT?
  10. wore out
    15,924
    192,699
    Jun 5, 2013
    Denso R5 is what we been putting on. MHC kenworth seems to have the best deal in our area. They are a little pricey but starter problems are over. Sorry I can't remember what they cost.
    BoxCarKidd and blairandgretchen Thank this.
  11. 062
    062 Road Train Member
    6,213
    33,453
    Oct 20, 2013
    Around here carquest has the best price on starters and alternators. No core charge either so you can rebuild old one.
