The best GPS ever
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Beer Runner, Oct 27, 2013.
  1. Beer Runner
    Beer Runner Medium Load Member
    544
    227
    Nov 2, 2010
    Canada
    I have had the 510 Rand for the last few years now, and picked up the Garmin 760 a few days ago. For the fun of it I ran them together to see which one was the best one. I found out that they will route you the same way. Only Garmin did a better job, but Rand picks up all the truck stops. I'm finding out that running the Garmin for the route is the way to go, but Rand will find the truck stops. Work both for the best performance. There you go the best trucker GPS is Garmin and Rand mixed.
  3. STexan
    STexan Road Train Member
    14,963
    29,154
    Oct 3, 2011
    Longview, TX
    They both route you the same way, yet Garmin did a "better job"? Can you elaborate? Faster? Which one finishes recalculating new route first when you deviate?
  4. Oscar the KW
    Oscar the KW Going Tarpless
    12,246
    28,116
    May 19, 2011
    I'm running a Rand 510 and a Garmin 560 together, the Garmin is 10 times faster at routing and recalculating than the Rand. The Garmin is faster at everything, but there is only two things off the top of my head that I like about the Rand, the truck stops, etc. on your route, and it shows what mile marker you are at. If the Garmin had those capabilities then it would be the only one on my dash.
    GeorgeDee Thanks this.
  5. SilverShadow
    SilverShadow Light Load Member
    121
    68
    Nov 14, 2008
    Terre Haute, IN
    Run the same test with the 520/720 against the dezl series to be fair. 520 beats the 510 hands down because of hardware changes. Same way as the 465 versus 560.
  6. PST
    PST Light Load Member
    125
    53
    Sep 7, 2009
    USA
    I have 2 new GPS units, the Garmin (dezl 760LM). and the Rand Mcnally (TND720). Both have led me down Residual streets and both have taken me in the wrong direction and both have taken me to bridge height's bellow 13 ft 6 in and yes they are both configured for truck routes and bridge height's above 13 ft 6 in. There are no perfect GPS units.
    Charli Girl Thanks this.
  7. STexan
    14,963
    29,154
    Oct 3, 2011
    Longview, TX
    Software (routing code) programming aside, a GPS is only as good as it's base map data (Navteq) and when you consider the billions of options a map database provides for cars by default, and it has to make [much] different determinations and allowances for trucks (of all types and HM considerations), it's a wonder they do as well as they do. (Any of them)
    Dieselboss Thanks this.
  8. Oscar the KW
    12,246
    28,116
    May 19, 2011
    How does it beat it? What does the 520 do so much better than the 510?
  9. Ridgeline
    22,376
    116,121
    Well there isn't really the best nav unit, they are still evolving.
    I came to the conclusion that if I want the best, I would go to a company that makes the same unit that goes into planes and is used by the military - Garmin.
    When I had problems, I didn't have to post on forums to get answers or play games with tech support. When there were errors in the mapping data, I send the error to one place and get a reply - that is the company itself who can make the correction.
    Taken in account that Garmin has been doing this a lot longer, has solid specs and requirements for their products, it seems it shouldn't be an issue with selecting what tools we use.
  10. black_dog106
    black_dog106 Road Train Member
    1,786
    1,666
    Mar 29, 2009
    MA
    AS littlereddog said, there is no perfect GPS. That being said, i would hate to be without a GPS unit now. However, nothing is perfect, i expect to put some thought into the routing and the day. I still keep maps in the truck, in case i have any doubts or questions.
  11. Mr. Jay
    Mr. Jay Light Load Member
    89
    38
    Jun 17, 2013
    Colorado Springs, CO
    Frankly, the best GPS is the one between your ears. A navigational aid is nothing more than a tool.
