Thermo king reefer water pump leak
Discussion in 'Refrigerated Trucking Forum' started by bluerhino, Nov 14, 2019.
  1. bluerhino
    bluerhino Light Load Member
    107
    7
    Mar 10, 2013
    Good evening all i have a thermo king reefer sb 210 leaking coolant around the water pump can it be replaced by any mechanic or thermo king shop only need your advice and ideas iam in Columbus Ohio will really appreciate your suggestions thanks
  3. reeferwrencher
    reeferwrencher Medium Load Member
    565
    1,485
    Aug 4, 2018
    Any mechanic,it's very easy to to do on those units.Probably do it yourself.
    062 Thanks this.
  4. bluerhino
    107
    7
    Mar 10, 2013
    Thanks for your response need some tips
  5. reeferwrencher
    565
    1,485
    Aug 4, 2018
    Draincock for the coolant is under the starter.Put a hose on and drain coolant.Remove gear clamp from upper rad hose and pull hose off.Remove 4 ten mm nuts from pulley and remove pulley.Remove 3 12 mm bolts from water pump and gently pry pump off with a screwdriver at thermostat housing. Scrape old gasket off block.Swap thermostat to new pump and install new pump with new gasket that's supplied with it.Pour coolant back in system at coolant bottle.Run unit until thermostat opens and top up coolant.
    baha, 062 and Snailexpress Thank this.
  6. bluerhino
    107
    7
    Mar 10, 2013
    Reeferwrencher thanks for your xtra effort can I run the reefer for day so that I deliver the load before the water pump replacement what are the scenarios that I might come across is keeping eye on coolant level ok
  7. 062
    062 Road Train Member
    6,215
    33,462
    Oct 20, 2013
    Just keep your eye on coolant level and engine temp. I ran with a leaky pump for a week until I could get home. The leak probably looks worse than it is. I only lost about a gallon of coolant.
  8. bluerhino
    107
    7
    Mar 10, 2013
    Thanks 062 does napa carry thermo king reefer water pump or is it exclusive thermo king dealer only
    062 Thanks this.
  9. 062
    6,215
    33,462
    Oct 20, 2013
    I never checked because I needed it right away. My guess is they would have to order it. You should be able to find one online if you can wait for it.
  10. reeferwrencher
    565
    1,485
    Aug 4, 2018
    Go to Thermo king and ask for the updated water pump as this is supposed to be a solution for the head gasket failure issue on those engines.Also take a look at the coolant bottle,if it is turning black then the head gasket is failing. Good luck.
    062 Thanks this.
