ThermoKing Alarm 63.
Discussion in 'Refrigerated Trucking Forum' started by sarmi, Dec 14, 2015.
  1. sarmi
    sarmi Bobtail Member
    Aug 20, 2014
    Weston,FL
    Hey Drivers! Need some feedback, how many of you have a ThermoKing Precedent C-600 and had an Alarm code 63?? I'm having big issues with mine costing me so much down time and the unit is only 1200 hrs old, ThermoKing had the opportunity to fix it 5 times in 3 different ThermoKing locations around the states and still shutting down. I can't even sleep when I'm loaded. Some help here, I need to know if is just me?? Thank you!!
    Dominick253 Thanks this.
  3. bigkev1115
    bigkev1115 Road Train Member
    2,364
    3,618
    Oct 23, 2009
    Alexandria, AL
    Code 63 is showing Engine or Vapor Motor stopped on the TK Alarm chart. It also shows that this particular code requires immediate attention
  4. STexan
    STexan Road Train Member
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    That sucks. This your trailer? Buy new? I'd start proceedings to make them replace the unit if they can't fix it. They going to buy the first load of rejected product, in addition to give you a new unit?
    Start writing professional letters to TK corporate and see if you can't rattle some cages to get a tech who understands what the issue likely is to advise your local dealer how to proceed.
    TK places high emphasis on their name and reputation, and this is likely some anomaly that got out and they need to get it out of circulation and/or determine if there are other similar issues cropping up recently that need to be addressed before you and others start giving TK bad press that they aren't used to.
    Was anything ever replaced on the other shop interactions? Like a bad sensor "lying" to the main control module.
  5. STexan
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    Just curious. Does this issue make your system inoperable? What happens when the code is cleared and the unit is power-cycled? What is being done to get it back running?
  6. Flipflops
    Flipflops Heavy Load Member
    734
    965
    Oct 18, 2015
    On my previous reefer trailer I kept having the same code. Thermo king never fixed it, even tho they always "did" but few hours later same thing. Typically this code is saying that the engine stopped. Which can be for a couple of different reasons. You might have a problem with the wiring/battery/electric (groundwire) issue. You might have problem with your fuel. Have you been in freezing areas lately? Could be a fuel pump, but fuel also might have got frozen, and they might fix it, but down the road it freezes again. After that code does it keep running or does it shut off? Also does it start back up once you clear the codes or does it try but fails? Does it give you any other codes after a few tries? Such as draining the battery voltage quickly?
    If you go to thermoking again, tell them you been 5 times already, and what happens. On a brand new trailer I had it was the o-ring that was messed up was leaking freon , which threw me a lot of codes including code 63.
  7. Alexdybin
    Alexdybin Bobtail Member
    Hey so did u fix it? Wat was wrong with it? Im haveing the same problam and dealers dont do enhthing they charge me for labor but it keeps shuting down
  8. Vio
    Vio Light Load Member
    150
    67
    Sep 25, 2012
    AZ
    I have brand new trailer with TK C600 and I got code 63 few times .The engine is stoping , I clear the code and is working again.
  9. 062
    062 Road Train Member
    6,144
    33,186
    Oct 20, 2013
    Check your ground wire to the motor. I have a sb210,it would shut of randomly. Found a bad ground on bottom left side of motor.
    Vio Thanks this.
  10. Truckster101
    Truckster101 Bobtail Member
  11. Truckster101
    Having same problem did you get it fixed and what waa the problem
