CHP reminds drivers about required brake check after runaway truck crashes
Kinda perfectly named company
They put those brake check pull off's there for a reason.
Discussion in 'Trucking Accidents' started by supersnackbar, Mar 31, 2022.
Page 1 of 3
Out of curiosity, what do you guys do at those brake check stations? I pull in and leave. But I also work on my own truck, and I have an ISX, so I never use my brakes going down hill anyway.
But what are you supposed to do? Check clearance? Adjust brakes?bzinger, austinmike, Mototom and 2 others Thank this. -
A lot of states (California,North Carolina,Tennessee,West Virginia,Utah just to name a few) set up surveillance cameras at the brake check areas to make sure drivers are actually stopping there to do a brake check. If they see a truck bypass it and then wreck down on the grade they can review the footage to see if that driver stopped before going down! Once they see that said driver failed to stop as mandated that driver is in some serious trouble!
Layman’s terms: You’re in deep s*** ,Jack!!!Last edited: Mar 31, 2022
WildTiger1990, gentleroger, Magoo1968 and 2 others Thank this. -
chimbotano and God prefers Diesels Thank this.
If I've been driving all day I'll get out and do a walk around too. Caught some loose hub bolts that way once.God prefers Diesels and D.Tibbitt Thank this. -
chimbotano, D.Tibbitt, God prefers Diesels and 1 other person Thank this.
Smoke your brakes rolling into the check station..Now that they are preheated, roll on!
Most of those check stations are clogged up with trucks taking a ten anyway..I don’t bother. -
I'm usually pretty light on my brakes coming down a grade. I've gone down the grapevine several times without touching my brakes. My engine brake does the work and basically the heavier I am, the slower I go down a grade anyway.
I do grades routinely running the West as I do. So, don't have any issues with them. But, always respect them. Never take one faster than is safe for my weight. For going down a grade, it's all about weight. I do stop at the mandatory brake check spots, but have to confess, I don't really do anything while there.JoeyJunk, chimbotano, D.Tibbitt and 3 others Thank this.
Page 1 of 3
