TK S-700 new reefer unit on 35 hours can’t get to -15 ?
Discussion in 'Refrigerated Trucking Forum' started by Verdel, Jul 10, 2024.
  1. Verdel
    Verdel Medium Load Member
    599
    135
    Oct 26, 2013
    Hey guys, I have a brand new TK S-700 and yesterday was 120 F in Las Vegas. Went to get some ice cream … the shipper requested to set the temperature to -15 F … the reefer has been running for 8 hours and the best temp was -7 F. They refused to load me and now I don’t know is there a problem with the unit or maybe was the outside temperature? No codes or anything, should I go to Thermo King to check the unit for low Freon or something? Some of the reefers at this shipper were at -17 F, but the drivers said: Ooo it has been running for more than 24 hours.
    What do you think? Should I go to Thermo King for a check up or this is normal in 120 F outside temperature?
  3. ‘Olhand
    ‘Olhand Cantankerous Crusty
    6,723
    16,474
    Jan 18, 2011
    Too many variables….type of trailer
    Trailer specs
    How hot was wagon when you started precoolin are just first few that come to mind
    but if it dropped to -7 in that heat
    I doubt your unit has a problem
    Rookie driver 956, ducnut and Verdel Thank this.
  4. goga
    goga Heavy Load Member
    895
    1,586
    Nov 11, 2021
    Earth..
    120F, empty trailer, that's a lot of empty air to cool. Your setup is just fine if it pulls to -7 empty. If it were loaded, less air to cool, quicker cooling occurs.
  5. Verdel
    599
    135
    Oct 26, 2013
    When I started the engine inside temperature was 115 F.
  6. abyliks
    abyliks Road Train Member
    3,924
    9,195
    May 2, 2010
    ludlow MA
    Did you pre cool before going there or did you just roll in for a load of ice cream with the unit off?
    doubt it will drop much more before the sun goes down, 127* temp difference is actually pretty impressive ..
    Verdel and mitrucker Thank this.
  7. mitrucker
    mitrucker Road Train Member
    5,328
    9,628
    Dec 15, 2010
    Lapeer, MI
    Curiosity question
    Why wouldn’t the driver have that unit running while they were driving to the pickup point? Especially for an ice cream load.
  8. Lazer
    Lazer Road Train Member
    1,802
    2,872
    Jan 22, 2017
    You say a ‘brand new unit’, is the trailer and refer unit brand new, or new reefer put on an older box?
  9. bryan21384
    bryan21384 Road Train Member
    15,003
    32,583
    Sep 18, 2009
    Memphis, TN
    I can't believe they won't load you. 7 below is pretty good in those types of temps. I don't know why they think 5 below is so much colder than 7 below. The ice cream will still be ice cream right? Anyway, as your reefer ages, you'll have to do manual defrosts to help with the cooling process. Also, you may need to stuff paper towels in the holes in each corner on the inside of the trailer to keep any bit of heat out.
    goga and mitrucker Thank this.
  10. ducnut
    ducnut Road Train Member
    2,580
    7,774
    Dec 31, 2010
    SPI
    A reefer is meant to maintain a set temp, with a load inside the trailer; not make miracles happen that stupid people come up with.
    boneebone and buzzarddriver Thank this.
  11. ‘Olhand
    6,723
    16,474
    Jan 18, 2011
    While true….. that ship sailed 20+ years ago now
    You can’t even reason with some of these Shippers and Cold storages anymore. Get the unit to 15 below they tell you to back in you open the doors by the time you hit the dock interior temperatures back up to 50° plus the whole thing is gotten ridiculous.
    Rookie driver 956, Verdel and ducnut Thank this.
