TND External Satellite GPS Antenna?
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Hanadarko, Dec 4, 2011.
  1. Hanadarko
    Hanadarko Independent Owner/Operator
    2,962
    927
    Oct 1, 2009
    Midwest
    Ok. Rand came out with the TND 500 a long time ago.
    My 1st purchase was Winter 2009.
    Gee, there is a tiny connector for an external GPS antenna on the back.
    Yet still, in all these years, Rand has yet to produce or develop any type of GPS antenna.
    The built in connector is smaller than an SMB.
    Has anyone been able to fashion up something that works?
    I have heard that some new International trucks are coming with built-in-the-dash Rand GPS units?
    - If so, how are THEY being connected for GPS??
    Surely someone must have a solution for this out there?
    :biggrin_25523:
  3. Corporal_Clegg
    Corporal_Clegg Road Train Member
    1,239
    605
    Oct 9, 2010
    Raleigh,NC
    Why do you need an external antennae? Are you having connectivity problems?
  4. SilverShadow
    SilverShadow Light Load Member
    121
    68
    Nov 14, 2008
    Terre Haute, IN
    [ame]http://www.amazon.com/Gilsson-Universal-Amplified-Adapters-Magellan/dp/B00073MP7Q/ref=pd_cp_e_4[/ame]
    universal that will work on the tnd
    Hanadarko Thanks this.
  5. Hanadarko
    2,962
    927
    Oct 1, 2009
    Midwest
  6. CanadianMoose
    CanadianMoose Bobtail Member
    13
    6
    Sep 7, 2011
    Toronto, Ontario
    I ordered the add on gps antenna from pc miler, for they're 550 ($25), and it fits perfectly...works great as I hav my 710 mounted directly to the face of my dash....
    Moose
  7. Hanadarko
    2,962
    927
    Oct 1, 2009
    Midwest
    My TND 700 does not have an ext antenna connection but both my TND 500 series units do. :biggrin_25512:
  8. CanadianMoose
    13
    6
    Sep 7, 2011
    Toronto, Ontario
    I installed the aux antenna, and with the unit set to gps info, I found it gave me 2 more satellites than without it.... should work for you even if it's not up at the windshield....
    Moose
  9. Mark Kling
    Mark Kling Technology Contributor
    10,935
    4,216
    Sep 23, 2007
    Statesville, NC
    Rand has had them before in the Rand Store, but due to manufacturing issues they were not restock. Currently Rand is looking at the connector and trying to "beef" it up a little.
    Some TND's did not come with a external TND antenna as this was in the production run for a certain run due to new molding plates being made.
    I have testers run the TND mounted with velco on their dash faceplate with no issues. It will also depend if you go a lot of driving in cities with tall buildings or in mountainous areas.
    Thanks,
    Mark
  10. Dieselboss
    Dieselboss Technology Contributor
    1,648
    1,365
    Feb 19, 2009
    DieselBoss.com
    I've had them for years - $29.
    And yes, some of the early units did not have the external connection in the back.
    Finally - yes there are occasions where it (regardless of brand or model) can get what I call "dementia" whereby it suddenly shows you off the road or several blocks away and then jumps back to where you actually are. This has to do with multiple factors, including weather, buildings, RF interference, your truck, location, direction of travel...
    If you want to see it happen 99% of the time, drive thru Times Square in NYC.
    Mark Kling Thanks this.
