To everyone that has white coat syndrome when getting BP taken.
Discussion in 'Questions From New Drivers' started by longhairdontcare, Sep 18, 2018.
  1. longhairdontcare
    longhairdontcare Light Load Member
    84
    153
    Sep 4, 2016
    All you have to do is get a doctors note saying your blood pressure is below 140/90 and you will be good to go. I went up to walgreens pharmacy, had to sign a paper, he took me into a room and tested both arms. Both under 140/90. He signed the paper and listed my readings. I'm using this paper for the place that I took my dot physical.
    TravR1 and tscottme Thank this.
  3. Tb0n3
    Tb0n3 Road Train Member
    4,689
    9,444
    Oct 5, 2012
    Earth
    If you're that close you might want to deal with it instead of sweeping it under the rug.
  4. Moose1958
    Moose1958 Road Train Member
    15,258
    33,816
    Dec 17, 2010
    Williesburg, Virignia
    My right eye twitches when it reads BS, it's twitching like heck right now! NOWHERE on the official FMCSA medical form do I see a blank that allows the ME to refer to a previous BP reading. I do not know if you are spreading BS or you have encountered a crooked ME. There is enough myth and BS posted in here as it is.
    roshea, spindrift and Puppage Thank this.
  5. longhairdontcare
    84
    153
    Sep 4, 2016
    I have no reason to lie. You can call up a DOT physical location right now and tell them you have white coat and ask them if you can get a signed and dated letter from a doctor/pharmacist etc saying your blood pressure is normal and you will be in the clear.
    Call them up.
    jsnell Thanks this.
  6. longhairdontcare
    84
    153
    Sep 4, 2016
    Why??? My blood pressure is as low as 125/75 at times. It's only when I am getting my physical that it shoots up to something like 155/85.
    austinmike Thanks this.
  7. Moose1958
    15,258
    33,816
    Dec 17, 2010
    No point. I'm sure over time when drivers attempt to do this and find out it is BS they will reply. Im a regulation wonk! I need to see this allowed for PER FMCSA REGULATION or it's BS. Goodbye!
  8. longhairdontcare
    84
    153
    Sep 4, 2016
    Nope... White coat is a legit disorder. I even found a few other posters saying they used doctors notes to pass.
    Here's one from post #6 in the thread below.
    Phobia of Doctors Office, What to Expect from DOT?
    And someone else mentioning it in post #20 of this other thread.
    HELP!!!! White coat syndrome stopping my physical
    jsnell Thanks this.
  9. pmdriver
    pmdriver Road Train Member
    2,338
    3,503
    Nov 14, 2017
    If they were serious about monitoring blood pressure correctly a reading would be needed about a half dozen times over a duration then average it out. Our pressures change during the day and for different reasons but if it is running high or you get drastic changes its best to address why.
    Tb0n3 and Aamcotrans Thank this.
  10. longhairdontcare
    84
    153
    Sep 4, 2016
    ABSOLUTELY. Apparently the rules have been recently changed and rightfully so. It is simply unfair to test ones blood pressure once/twice and deem them with high blood pressure. A lot of things can be wrong on that day. Having a qualified doctor sign off on you having normal blood pressure is how it should be as they will know how your readings are on average.
    jsnell Thanks this.
  11. Moose1958
    15,258
    33,816
    Dec 17, 2010
    I never said white coat was not a problem. I suffered from it. I am saying to the best of my knowledge the FMCSA does NOT ALLOW an ME to accept letters like this. Show me a reg or regulatory guidance that says otherwise and I will admit RIGHT HERE I am wrong. Also in that one thread you linked to. Number 6 in my opinion is either telling a bold face lie or has totally misunderstood what was happening. These forums are full of BS. Just because someone says they did it does not mean they actually did.
    06driver Thanks this.
