trailer leaning to one side
Discussion in 'Experienced Truckers' Advice' started by Vintage, Jun 6, 2015.
  1. Vintage
    Vintage Light Load Member
    142
    117
    Mar 16, 2013
    Sea to Shining Sea
    Hello TTR good day to you all guys and gals. I hope this message finds you all in good health and spirit. Alright here's the question. So, I just picked up a 53' great dane reefer, everything checked out and looked okay when we went to go kick the tires. Picked up the first shipment with it today and noticed that once loaded, the trailer is leaning to the right(passenger). Do any of you know what could possibly cause a trailer to lean to one side? The freight is not an issue as this is a frequent customer. Fifth wheel coupling checks out. A visual inspection of the under carriage revealed no readily identifiable causes for this issue. The cross members look okay, no audible air leak, air bag seem okay. So, anybody care to take a stab?
  3. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    CK. the hi. of each side air bag and you may find one isnt getting air?
    201 Thanks this.
  4. w.h.o
    w.h.o Road Train Member
    3,583
    4,094
    Jan 10, 2011
    Chicago, il
    Leaning or dog tracking
  5. coueshunter
    coueshunter Heavy Load Member
    728
    432
    Nov 23, 2014
    You weren't coming out of Ohio along 70 were you? Saw one really leaning last night. Maybe this morning on my route down to 44 and the 40
  6. Vintage
    142
    117
    Mar 16, 2013
    Sea to Shining Sea
    thanks I'll check
    definitely leaning
    nope..another fella with the same kind of issue i reckon
  7. wichris
    wichris Road Train Member
    4,246
    8,493
    Jan 17, 2011
    If it sits level MT and leans when loaded its most likely suspension binding up.
    lots of character and RedForeman Thank this.
  8. 201
    201 Road Train Member
    12,128
    24,741
    Apr 16, 2014
    high plains colorado
    Hi Vintage, you didn't say if it had air ride or spring, but it's probably air, if it's leaning. Definitely an air bag issue. When I worked for the egg company, we had some really tired Kohl's trailers that had early air ride, and that was a constant situation. The old trailers if I'm not mistaken, used 2 leveling valves, 1 for each axle, but I'm sure they just use 1 now for both. If 1 or both bags don't look like the other side, the valve or perhaps a line. I'd look into that, as on a curve, loaded, that could cause a problem.:biggrin_2554:
  9. wichris
    4,246
    8,493
    Jan 17, 2011
    Common problem with 5-6 year old hendrickson suspension. Bushings seize up and don't allow full travel. Just stop at a shop that has a bumper lift. Raise it real slow and you'll find one wheel position that comes off the ground before the others. That's the seized bushing.
  10. McCauley
    McCauley Medium Load Member
    621
    783
    Jun 23, 2013
    Tell the immigrants inside of it that they need to spread out instead of all sitting on one side.
  11. 201
    12,128
    24,741
    Apr 16, 2014
    Ha, that's hilarious!:laughing3:
