Trailer picked up
Discussion in 'Experienced Truckers' Advice' started by teams567, Feb 2, 2024.
  1. teams567
    teams567 Medium Load Member
    405
    469
    Jan 3, 2022
    Picked this one up.
  3. Barricadebouncer
    Barricadebouncer Light Load Member
    143
    165
    Apr 11, 2022
    Have you had a blowout yet?
  4. 201
    201 Road Train Member
    12,627
    25,926
    Apr 16, 2014
    high plains colorado
    Just a recap seam, could last a year or 5 minutes. Tread looks about gone anyways, I doubt it would pass an inspection. I'd write it up, then you are kind of covered.
  5. Barricadebouncer
    143
    165
    Apr 11, 2022
    Or put out of service and probably cited with a violation and fined.
    § 393.75 Tires.
    Except as provided in paragraph (b) of this section, tires shall have a tread groove pattern depth of at least 2⁄32 of an inch when measured in a major tread groove. The measurement shall not be made where tie bars, humps or fillets are located.
    201 Thanks this.
  6. Long FLD
    Long FLD Road Train Member
    12,502
    51,949
    Mar 4, 2015
    Just a recap seam. As long as the tread depth is legal just run it til you can’t.
    MACK E-6, JoeyJunk, Speedy356 and 3 others Thank this.
  7. Grumppy
    3,174
    11,079
    Dec 11, 2010
    West Monroe, La
    I agree. Its just a recap seam. It's normal. If you look close enough, you'll find it on every recap. Its there. You may not notice it, but its there.
    MACK E-6, JoeyJunk, Speedy356 and 4 others Thank this.
  8. hope not dumb twucker
    5,890
    51,242
    Aug 23, 2022
    If it’s under depth get it fixed. Just watch it closely, you see it starting to separate or peel. Get it replaced asap.
  9. Numb
    Numb Crusty Curmudgeon
    4,226
    9,919
    Jan 30, 2012
    Charlotte, N.Carolina
    looks illegal, the other one doesn't look much better.
    I wouldn't run them with a lot of weight.
  10. DixonM
    DixonM Medium Load Member
    377
    786
    May 22, 2022
    Looks good to me it’s a recap they all have a seem in the tread also I like to inspect the side of the tread to make sure it is not peeling off. Legal tread depth is 2/32 for all tires except steer and 2/32 to me looks #### near bald.
    hope not dumb twucker and Oxbow Thank this.
  11. buzzarddriver
    3,714
    10,998
    Feb 1, 2011
    Dallas, TX
    Lincoln penny test. Put the penny in the groove with Lincoln's head pointing down. If you see space above his head, the tread has less than 2/32" tread and needs replacing. Test should be done at three(3) different spots around the tire.
    hope not dumb twucker and Numb Thank this.
