? Triple Crown Trailers
Discussion in 'Experienced Truckers' Advice' started by allis327, Nov 25, 2014.
  1. allis327
    allis327 Light Load Member
    72
    54
    Aug 26, 2011
    Melrose mn
    Question about some of Triple Crowns trailers. On their 53' trailers it looks like they have a pintle hitch in front and some kind of a recessed hitch under the floor. Any idea?
  3. Balakov100
    Balakov100 Road Train Member
    3,937
    2,635
    May 10, 2012
    Temple, TX
  4. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    Back in the 80s they had a few trailers leave the RR tracks before they learned to keep them on the rails.
  5. MsJamie
    MsJamie Road Train Member
    Yes, those are RoadRailers. Norfolk Southern pulls them. I must admit to doing a double take when I first saw then rolling down the track.
    x1Heavy Thanks this.
  6. Mike2633
    Mike2633 Road Train Member
    6,461
    25,988
    Jun 14, 2013
    At Home on The West Side
    Triple Crown is the only road railer fleet out there. It was a joint venture between Conrail and NS and now that Conrail is gone it's all NS.
    I think Swift in the late 1990's early 2000s had a fleet of road railers riding the rails in California.
  7. dgman
    dgman Light Load Member
    182
    159
    Mar 8, 2011
    Philadelphia, PA
    Yes, the basically put train wheels (also called trucks) under them and connect them together to make a train. That is how the majority of Triple Crown roadrailers are moved via rail. They are some of the biggest POS you will see on the road. See them pulling out of the Triple Crown yard at the NS Rutherford rail yard in Harrisburg all the time. Many times when I was pulling tin cans I had to sit and wait for one to pass. View attachment 74818
  8. skellr
    skellr Road Train Member
    8,737
    12,184
    Jul 17, 2011
    The Village, Portmeirion
    I'm surprised they can handle that much stress.
  9. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,130
    Mar 5, 2016
    White County, Arkansas
    If I remember right you string em together, put rail under them, hitch a choo choo and off you go.
    So goes the theory.
  10. x1Heavy
    34,017
    42,130
    Mar 5, 2016
    Actually the two axle rail wheel assembly is its own stressor. The weight of whatever it has on it just sits in a large hole in the center top between the axles of the Rail truck assembly. Then you have your braking and air supply etc else where.
    IF you were God and playing with those real life train cars and accidentally knocked one over, the wheels axles and frame of them will stay on the rail. The body of the boxcar or whatever you knocked over will come off there as a complete unit. Its held in place by gravity only.
    skellr Thanks this.
  11. skellr
    8,737
    12,184
    Jul 17, 2011
    I was just thinking about the length of the train and how much stress was on the first trailer pulling all the ones behind it. Even if they were empty, that's alot of weight to pull.
