Truck idle and using the air brakes
Discussion in 'Questions From New Drivers' started by paccarmike, Jun 4, 2021.
  1. paccarmike
    paccarmike Bobtail Member
    39
    30
    Jul 9, 2014
    Washington
    My company doesn't allow me to idle the truck. I have a 2021 frieghtliner cascadia. They set the idle limit to 3 minutes. Opti idle is pos and does not keep the truck cool. I can idle the old school way of popping the trailer brakes and releasing the tractor brakes. If I do that when loaded (gross 93k) would the trailer brakes hold me if on a slight decline? Wheels are not chocked.
  3. buddyd157
    buddyd157 Road Train Member
    13,576
    34,885
    May 25, 2017
    under a shade tree
    i would not trust the brakes at any time, to be in perfect adjustment.
    and your idea of a "slight incline" will most certainly NOT be the same as mine or anyone elses.
    you have choices
    1) seek another employer that has APU's on thier equipment
    2) buy a device to keep the throttle pedal slightly depressed.
    check auto parts stores ( or online) for something like this
    Thexton Universal Throttle Pedal Depressor - THE393
  4. lovesthedrive
    lovesthedrive R.I.P.
    15,953
    54,484
    Nov 11, 2008
    Sorrento Maine
    Yard stick.
    Or turn on cruise, touch resume so your above idle
    Cowboyrich and buddyd157 Thank this.
  5. roundhouse
    roundhouse Road Train Member
    3,179
    7,232
    Jul 11, 2018
    Next time you’re ate the terminal and dispatch office. Walk around back and shut off the power to the AIr conditioning units.
    See how they like it.
    I would at least get some good wheel
    Chocks
  6. lovesthedrive
    15,953
    54,484
    Nov 11, 2008
    Sorrento Maine
    :biggrin_25514::biggrin_25523::biggrin_25514:
  7. buddyd157
    13,576
    34,885
    May 25, 2017
    under a shade tree
    that's IF the power panel is not padlocked.
    either that, or put a tarp over the condenser.....that'll sweat'em out as well.
    Capacity, Speed_Drums, Coffey and 6 others Thank this.
  8. Arctic_fox
    4,189
    22,001
    Sep 16, 2016
    Find the thermometer probe the truck uses and put an 8 hour hand warmer on it. Works like a charm. Better idea, find a company thats not stupid and has either old iron, APUs or no anti-idle.
  9. Dave1837
    Dave1837 Road Train Member
    1,401
    4,345
    Nov 16, 2019
    Pennsylvania
    Yes they'll hold. Chances are your tractor only has 2 parking brakes anyway. You could get a wheel chock just to be on the safe side
    paccarmike and Farmerbob1 Thank this.
  10. Dockbumper
    Dockbumper Road Train Member
    3,778
    9,860
    Apr 29, 2020
    Make sure you are using the opti idle properly. I was issued a 19 Cascadia a couple of years ago. Worked just fine. I think I needed to leave the ignition in the on position and use the bunk controls. Google it. The engine is running the same Air Conditioning compressor whether you are idling or using opti idle. Better yet, call the company shop and ask them how to use it.
    gentleroger, tscottme and Farmerbob1 Thank this.
  11. Dockbumper
    3,778
    9,860
    Apr 29, 2020
    That ain't gonna work on a 2021 Freightliner. That trick has been gone for a long time.
    bzinger, tscottme, 25(2)+2 and 4 others Thank this.
