Truck idle and using the air brakes
Discussion in 'Questions From New Drivers' started by paccarmike, Jun 4, 2021.
  1. paccarmike
    paccarmike Bobtail Member
    39
    30
    Jul 9, 2014
    Washington
    I do heavy haul so I'm permitted up to 105,500 here in the PNW. Slight decline meaning just enough to get the water to drain down to the other side of the lot. I'm going to buy something small that can hold down the throttle.
    Farmerbob1 Thanks this.
  3. abyliks
    abyliks Road Train Member
    3,931
    9,219
    May 2, 2010
    ludlow MA
    Bumping the idle with the cruise to 8-900 should be done any time you leave the truck to begin with, that may bypass the idle shut down
    if it does not, there’s plenty of other companies out there
    Farmerbob1 and RockinChair Thank this.
  4. Long FLD
    Long FLD Road Train Member
    12,070
    49,847
    Mar 4, 2015
    If you idle up a new truck it confuses the sensors and will pump too much def through and will eventually gum up the dpf.
  5. special-k
    special-k Road Train Member
    1,523
    3,258
    Dec 27, 2008
    Southern Ontario Canada
    The trailer brakes will be fine holding the unit in place. If you don't trust them set the trailer brakes and try to pull the trailer with the truck. If it moves without skidding tires take it to a shop. I don't anyone who engages all the brakes all the time regardless of the slope they park on.
  6. AModelCat
    160,763
    DEF gets injected after the DPF.
  7. Farmerbob1
    Farmerbob1 Road Train Member
    3,685
    5,791
    Jan 17, 2017
    Hrm. Based on where my DEF injectors are, and where my DPF filters are, that makes little sense.
    If I am right, there is BOTH a injector before the filters, and a flat pan holding more DEF inside the DPF filter assembly box.
  8. Long FLD
    12,070
    49,847
    Mar 4, 2015
    Idk. Just what I was told. If I idle mine up to 8-900 and go to bed I have to regen before I start driving but if I leave it at low idle then I don’t. I was told it was because idling it up makes the computer think it needs more def.
  9. AModelCat
    160,763
    There's actually 3 different catalysts in the aftertreatment. DEF is injected after the DPF and into the SCR. The DOC is first and is what gets dosed with fuel during a regen, which creates the heat needed to clean the DPF.
  10. Farmerbob1
    3,685
    5,791
    Jan 17, 2017
    At low exhaust temperatures, your buildup in the filters is based on the volume of exhaust passing through the filters. My truck slow idles at 600ish RPM, and I will guess yours does too.
    800 to 900 RPM with no load is not going to make enough heat to clean filters, so you are pushing 33 to 50% more exhaust through the filters, generating 33 to 50% more gunk overnight.
  11. Harry Flashman
    Harry Flashman Medium Load Member
    510
    1,360
    Oct 4, 2019
    The cruise control trick hasn’t worked on any truck I’ve driven in the past 4 years. Prior, I used to use it, but the truck manufacturers got wise to it.
  12. Six9GS
    Six9GS Road Train Member
    1,473
    3,695
    Dec 3, 2012
    Yuma, AZ
    I'd comb through the operator's manual to ensure I was operating the controls for the opti-idle correctly. I drive a Volvo, the controls in the sleeper berth are 'weird' and it takes a bit to understand how to get it all to work OK. However, I don't even have an opti-idle capability. I did eventually find how to cancel the idle shut off and if I really need to, I shut off the idle cancel and let that puppy run. On occasion I get fussed at for high idle times. But, I try diligently to keep idle usage down whe it is feasible. But, if I gotta get some sleep and the only way to do that comfortably is cancel the idle cutoff, I shut it down and let the truck run. It is imperative I get restful sleep to be safe. I can't get restful sleep when my sleeper cab is at 90 degrees or at 40 degrees (I do have a bunk heater that works really well and will keep sleeper berth comfy when it's as low as like zero outside).
