I have a 2016 Volvo D13. It very rarely regens going down the road, always makes me do a parked regent. Any suggestions?
Truck Not Regenning while moving
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by jazzman61, Feb 29, 2020.
Before you start doing requested parked regen you need to go in a menu and into a diagnostic sub menu and from there go and look up all the codes that truck will show you, better off taking a pictures of them so you can recall them in a future when someone will ask for them. Also go look at your soot level and take a picture also. Then start your regen take a picture again just to know when it started. When it’s done take a pictures again. And then you can post some of them here or give us the codes in a written form that helps ALOT. Without that info it’s hard to tell unless you want useless info on how to spend your money.
QUALITYTRUCK and Western flyer Thank this. -
Does the truck reach 200+ degrees water temperature during normal operation? If not, it might be unable to reach a high enough temperature to properly regen while you are driving.
For example, if you have a light load, are in cold weather, or if your truck has been configured for desert operations (extra fan / oversized radiator) it might never reach a high enough exhaust temperature to regen right.
I have a dd15 and I have occasionally chosen to try to drive-out a solid regen light that pops up after a 34 hour reset. It normally takes at least an hour of drive time to resolve. If the light goes to flashing status, I stop and regen so I don't build up enough pressure to break something in the filter system.
