Truck Won't Shut Off, TRLR and TRACT Abs On
Discussion in 'Ask An Owner Operator' started by Ker, Aug 10, 2020.
  1. Ker
    Ker Bobtail Member
    25
    16
    Mar 11, 2018
    Freightliner century 2007 Detroit d60 14 l.
    This always happens after rain, the only way to turn the truck off is by removing the instrument cluster fuse, if I put the fuse back the ignition comes back on, even if I took the key out.
    Can someone tell me what should I look for, cracked wires or bad chassis-ground connections, bad jacks ? If it's ground, how do i know which one is ground since they're all yellow and there's hundreds of wires.
    Thank you.
    truckdriver31 Thanks this.
  3. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    i would look at the key ignition myself first
    Ker Thanks this.
  4. baha
    baha Road Train Member
    4,137
    2,836
    Jul 25, 2013
    ga
    Look behind the drivers seat for a panel that pops off with a fuse box inside and has got water in it pull all the relays out and look for green on plug in on relays you can use a large zip look bag to put fuse panel in after you clean all plug ins and have it turning off like it did before?If your on the road you can buy a batt. cut/off switch like race cars use when you park it for the night.
    77fib77 and Ker Thank this.
  5. 201
    201 Road Train Member
    12,339
    25,228
    Apr 16, 2014
    high plains colorado
    Sounds like a Stephen King horror story,,:eek:
    Ker and Lpirtle Thank this.
  6. p608
    p608 Road Train Member
    2,181
    2,992
    Nov 10, 2016
    It's a Freightliner
    Ker and 201 Thank this.
  7. supersnackbar
    19,191
    47,577
    Aug 19, 2007
    Your Town, USA
    X2 on this advice. Had a Century that would do it's P.O.S.T.(power on, self test) like I turned on the key when I was parked during moderate rain storm. Thought my truck was possessed until I called my company's breakdown. They told me to do the same thing, and sure enough, when I opened the cubby door, it was raining inside the compartment almost as much as it was outside. Wrapped the connections with plasic Saran wrap and the problems gradually stopped. It stayed that way until I got to a shop where they could reseal the truck. Not sure what seam was leaking, they just shot silicone in every crack and crevice they could. Never had another ghostly episode after that.
    Ker and blacklabel Thank this.
  8. Ker
    Ker Bobtail Member
    25
    16
    Mar 11, 2018
    Thank you all, that was the actuall problem.
    77fib77 and baha Thank this.
  9. baha
    4,137
    2,836
    Jul 25, 2013
    ga
    Ker thanks for coming back to tell us what fixed it, So often we never hear back from drivers that are back on the road with truck fixed ?
