Ttr cdl practice test
Discussion in 'Questions From New Drivers' started by Rollin_18, Jan 24, 2013.
  1. Rollin_18
    Rollin_18 Light Load Member
    214
    19
    Dec 6, 2012
    Cleveland, Ohio
    I start school in Feb.(Not sure date yet but i know I will start in Feb.). Is the cdl practice test on here a good test to study from? how close are the questions to the actual ones on the test? The school i will be attending called cristcdl. Im just wondering which one is better but ive been taking the test on this website for about 3 months and pass it every time but im just wondering which on i should use? thanks in advance your response.
  3. rookietrucker
    rookietrucker Trucker Forum STAFF Staff Member
    10,061
    7,058
    Jul 15, 2007
    TEXAS
    If look above in the blue bar ^^ you should see "CDL PRACTICE TESTS"
  4. Rollin_18
    214
    19
    Dec 6, 2012
    Cleveland, Ohio
    yea this is the one i always study from but roadmaster gave me cristcdl to study from im just wondering which is better or are the same? i just went on cristcdl and took 2 of the GK test and passed one with 86% and the other 100% but the 86% was because they have a different answer for one of the questions then this site which the one on this site makes more since cause you should always back toward the driver side when possible and us a help if hand signals if possible and backing is always dangerous, but cristcdl said i was wrong for putting all the above and their correct answer was just backing is always dangerous.
  5. technoroom
    technoroom Heavy Load Member
    830
    459
    Nov 8, 2012
    I've taken the practice tests from both sites and found the questions very, very similar. And I know exactly which question on the CristCdl site you're speaking of; I also think it's being scored incorrectly - the answer should be "all of the above." There was one other question that was also clearly wrong and some the questions have garbled words etc. The tests on this site (TTR) seem to be of better quality.
    Admin Thanks this.
  6. ladyfire
    ladyfire Light Load Member
    148
    71
    Sep 6, 2010
    Greensboro, NC
    I just took the HM test using mostly Crist, and the questions were pretty much dead-on. Good luck.
  7. Homemade1959
    Homemade1959 Light Load Member
    130
    47
    Jan 21, 2012
    any of the 48 states
    why don't you just go to the SOS in your home state and get the dmv book study and get your tip before you start trucking school? then you can be ahead of your class and concentrate on the yard skills you will learn
  8. ‘Olhand
    ‘Olhand Cantankerous Crusty
    6,750
    16,653
    Jan 18, 2011
    Just a little hint here--on almost any multiple guess exam the instructions will read--mark the BEST ANSWER don't overthink it---yes there r numerous problem scenarios when backing BUT backing is Always dangerous is the better answer--since it covers all bases--food for thought
    Just saying
  9. 900,000-tons-of-steel
    900,000-tons-of-steel Road Train Member
    1,511
    896
    Aug 17, 2012
    Florida
    You're right. Although I know some drivers swear by the CristCDL test questions, more than a few are wrong in several different areas and endorsement test questions. I've contacted the site administrator about the site's incorrect answers and he corrected a few but ignored the others. I've steered new students away from that site because of the misinformation lately. One missed question on the actual CDL test could be the difference between pass and fail. Why take chances?
    http://cdlpracticetest.info/ is also a good site but steer clear of the CristCDL website questions until they get them all fixed.
    Rollin_18 Thanks this.
  10. Trucker Bug
    Trucker Bug Light Load Member
    117
    86
    Jan 24, 2013
    California
    This is the way to go.
    Go to DMV. Get the handbook. Read through it (I read mine while on the toilet) everything you need to know should be in there. Run down and take the tests. If you start school with your permit and endorsements you will be out there driving while everyone else is in class. You might also get a discount on the school since you do not require the class time for your permit/endorsements.
    Also get all the endorsements. Even if you only plan on pulling vans get the tankers and doubles/trips. It's the same cost to get 1 or all of them and you never know where you'll end up.
  11. Pmracing
    Pmracing Road Train Member
    6,354
    3,178
    Jan 28, 2011
    Arlington Heights, IL
    I think Rollin knows where the test is... heheheheheee
    Just funnin' with ya. I know you have a lot to peruse here.
    Mikeeee
