Turn up 3406e or not?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Ecnal regnew, Mar 8, 2016.
  1. Ecnal regnew
    Ecnal regnew Bobtail Member
    15
    Mar 4, 2016
    We've got a 1995 international with a 3406e low HP max at 380 with existing turbo. The thing works great but could use a little more power, since we live in the mountains. I realize the expense pistons, turbo, injectors, ect to go any more HP from caterpillar, but has anyone ever used the fuel temp and boost sensor harness? Or is this too much for this motor
    Appreciate any advice. Thanks
  3. Yves kanevil
    Yves kanevil Medium Load Member
    522
    465
    Jan 10, 2016
    Nighthawk
    Fuel temp sensors work good at adding HP. Boost sensors male for a more responsive fuel pedal but makes lots of black smoke because of the initial over fueling. I have used both. No engine damage can occur from these plugs
  4. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,729
    Jan 30, 2010
    keep stroking.
    Fuel temp sensor is a temporary fix. It only works until your fuel get up to operating temp. Boost harness only makes it smoke.
    Cetane+ Thanks this.
  5. AModelCat
    156,403
    Idk if I'd want to push for too much more power when you say that Cat won't uprate it because the components are at their limits. Don't know how well it would stay together.
  6. Hype6477
    Hype6477 Light Load Member
    230
    99
    Jun 19, 2015
    Socal
    IMHO if it isn't broke don't touch it. I pushed the HP on my 3406B snapped three exhaust manifold studs, I turned it back down after that.
  7. SmokinCAT
    SmokinCAT Road Train Member
    1,773
    1,487
    Oct 20, 2010
    Hillsboro, OH./ Adrian, MI
    Likely with that early of an engine it has aluminum pistons and odd ball hardware to go with(cam,injectors)
    AModelCat and Diesel Dave Thank this.
  8. Old school 362
    Old school 362 Medium Load Member
    392
    249
    Mar 6, 2016
    Pensacola Fl
    Leave it alone. My two cents
  9. CataB71
    CataB71 Bobtail Member
  10. CataB71
    No, doesn't work, in 5 min after you plug in the fuel temp harness your engine fan starts , and never stop , unless you remove it, about the other one doesn't do nothing beside smoking
