Vibration in steering wheel
Discussion in 'Freightliner Forum' started by tonycr, Mar 28, 2018.
  1. tonycr
    tonycr Light Load Member
    109
    20
    Feb 28, 2013
    2012 Cascadia,568,225 miles alignments straight the other day notice a vibration in the steering wheel any ideas what could cause it
  3. bigdad7
    bigdad7 Road Train Member
    1,837
    1,364
    Jun 6, 2010
    ks
    Tire driveline wheel bearing or just for fun injector actuator or even dropped a piston .......or you are driving in oklahoma
    John B. Hood Thanks this.
  4. blairandgretchen
    13,669
    74,390
    Dec 9, 2011
    South west Missouri
    Tire balancing.
    Tire out of round.
    Worn components.
    tonycr Thanks this.
  5. blairandgretchen
    13,669
    74,390
    Dec 9, 2011
    South west Missouri
    Nah - the injector actuators and dropped piston cause a burning sensation - in your pocket area.
    Tug Toy, rolls canardly and ShooterK2 Thank this.
  6. ShooterK2
    ShooterK2 Road Train Member
    5,533
    89,470
    Dec 14, 2012
    Oklahoma
    Run your hand around your steer tires. Inside and outside edges. If it’s cupping, it’ll sure make the steering wheel shake.
    tonycr Thanks this.
  7. rolls canardly
    rolls canardly Road Train Member
    1,624
    3,965
    Feb 7, 2009
    mt. pocono. pa.
    I got a Freightliner, too - that's normal.
    Sarc/
    So; if you do find cupping on the steer tires, is it acceptable to swap sides?
    I was told you don't do that cause of the direction of the belts inside.
    They get liking going one way and come apart if you change direction?
    I would think it makes no difference and stops shake, and cupping is "worn" off.
    Comments?
    ShooterK2 Thanks this.
  8. ShooterK2
    5,533
    89,470
    Dec 14, 2012
    Oklahoma
    I rotate my steers before they start cupping. I don’t know if rotating them after will fix it or not. Never had one come apart.
    rolls canardly Thanks this.
  9. Diesel Dave
    9,302
    29,929
    Jan 20, 2010
    Hesperia, Ca.
    I have rotated my drives like and X and never had an issue. The steers swap them and same.... never had an issue.
  10. tonycr
    109
    20
    Feb 28, 2013
    Bridgestone's I had good luck with them no cupping
  11. OneTwentyOne
    OneTwentyOne Light Load Member
    76
    22
    May 19, 2016
    Check your carrier bearing. I had bad vibration on my steers with good tires, alignment and CENTRAMATICS - found out my carrier bearing was worn. The shaft vibrates and it produces vibration in your steers. At least it did for me, once I changed the carrier bearing - smooth....
    tonycr Thanks this.
