Viesa nternal cab cooling
Discussion in 'Experienced Truckers' Advice' started by DUNE-T, Apr 10, 2018.
  1. DUNE-T
    DUNE-T Road Train Member
    6,944
    16,849
    May 10, 2015
    Detroit, MI
    Has anyone ever driven a truck with one of these installed? Summer is coming and I am curious if these things work well
  3. ChaoSS
    ChaoSS Road Train Member
    3,338
    6,758
    Sep 20, 2014
    Not that brand but yeah. They work well up to about 80 degrees or so I'd say, keep you pretty comfortable when it's too warm to be really comfortable inside the truck but not too hot.
    80-90 they keep things tolerable, but maybe not so comfortable.
    Up above that they turn hot a miserable into hot and miserable and muggy.
    Oh, and they won't work well where it's already high humidity. Southern California/Arizona, they can be really nice, while the temps are still lower. So if you sleep nights they can be pretty effective through most of the year. If you want it to work during the day at 115 degrees, forget it.
    One other nice thing is the ability to turn the water off and just run the air, bringing in cooler outside air so you don't have to open windows and hope for a breeze.
    DUNE-T Thanks this.
  4. buddyd157
    buddyd157 Road Train Member
    13,564
    34,840
    May 25, 2017
    under a shade tree
    it says that it's an evaporator system...meaning you are going to add MORE humidity on top of the humidity outside...
    those are like the evap systems that one can buy for say, his shop. but you need to use them in a dry area, like the southwest....
    anyplace else, and it's counter-intuitive to keeping you cool and humid free.
  5. buddyd157
    13,564
    34,840
    May 25, 2017
    under a shade tree
    from the owners manual:
    Cooling is generated by vaporized cool water delivered by a self-contained electrical motor. During operation it only consumes water and it makes no use of internal combustion engines, nor does it use chemical coolants or emit gases into the atmosphere.
  6. Hoofbeats
    Hoofbeats Road Train Member
    1,250
    1,991
    Jan 27, 2010
    Iraq
    Sounds like a swamp cooler.
  7. Ridgeline
    22,389
    116,322
    That's what it is. Won't work in say the Deep South where there is a lot of humidity.
  8. snowwy
    snowwy Road Train Member
    20,553
    13,281
    Jul 6, 2009
    You mean the Humidity of the east.
    The southwest is just dry and hot. :)
    So, they'll only work on the west and north.
    There used to be small swamp coolers and air conditioners. Hard to find these days. For the cheap and economical.
  9. Meteorgray
    Meteorgray Heavy Load Member
    754
    597
    Jan 1, 2016
    Down along the Gulf Coast you could get charged with attempted murder by adding moisture to air with 100% humidity. It could drown you with a cabin rainstorm :)
    Down where there are swamps, those things won't cool a swamp; they create a swamp.
    buddyd157 and Farmerbob1 Thank this.
  10. Farmerbob1
    Farmerbob1 Road Train Member
    3,685
    5,791
    Jan 17, 2017
    That's exactly what it is, from what I read. It will be useless in humid conditions, and marginally effective in very hot weather.
    It will also certainly need regular filling with water, and the manual will likely tell you it needs distilled water, or the tubes and whatnot might get clogged by minerals.
    If you operate locally in Arizona, Nevada, or some other places where it is low humidity most of the time, it might be worth installing, but don't expect to use it for all your cooling needs.
