Vision test question
Discussion in 'Questions From New Drivers' started by SPcbr, Jan 19, 2016.
  1. SPcbr
    SPcbr Bobtail Member
    Jan 19, 2016
    Elgin, IL
    Hey, everyone.. I'm hoping to enroll in school within the next month or so. I use glasses to see, but I was told by someone that they don't let you use glasses or contacts for the DOT eye exam. Is this true, or will I be able to take the test with glasses on?
    Thanks,
    Scott P
  3. O.Henry
    O.Henry Road Train Member
    1,153
    2,282
    Sep 1, 2012
    San Antonio,TX.
    What does DMV say?Do your own research for the correct information.
  4. TigerShark
    TigerShark Medium Load Member
    454
    329
    Nov 5, 2015
    Just go take the test and when its vision time throw your glasses on like a boss and tell them to stick it.
    SPcbr, pologang859 and bottomdumpin Thank this.
  5. Robd1178
    Robd1178 Light Load Member
    75
    94
    Oct 16, 2015
    If you need glasses to drive then they'll let you, but it will be required to wear them at all times while driving.
    superflow, ajohnson, SPcbr and 3 others Thank this.
  6. blairandgretchen
    13,377
    71,914
    Dec 9, 2011
    South west Missouri
    It's usually noted on the license itself, right?
    flood Thanks this.
  7. Moose1958
    Moose1958 Road Train Member
    15,169
    33,411
    Dec 17, 2010
    Williesburg, Virignia
    Yes, its on both your license and medical card that you must have vision correction while driving.
    SPcbr and Longarm Thank this.
  8. pologang859
    pologang859 Bobtail Member
    20
    Jan 20, 2016
    Do u have to have 20/40 vision
  9. Moose1958
    15,169
    33,411
    Dec 17, 2010
    Below is taken right from the medical form. I think it about covers it.
    INSTRUCTIONS: When other than the Snellen chart is used, give test results in Snellen-comparable values. In recording distance vision, use 20 feet as normal. Report visual acuity as a ratio with 20 as numerator and the smallest type read at 20 feet as denominator. If the applicant wears corrective lenses, these should be worn while visual acuity is being tested. If the driver habitually wears contact lenses, or intends to do so while driving, sufficient evidence of good tolerance and adaptation to their use must be obvious. Monocular drivers are not qualified.
    Standard: At least 20/40 acuity (Snellen) in each eye with or without correction. At least 70 degrees peripheral in horizontal meridian measured in each eye. The use of corrective lenses should be noted on the Medical Examiner's Certificate.
    SPcbr Thanks this.
  10. SPcbr
    Jan 19, 2016
    Elgin, IL
    Thanks guys.. I will be enrolling in school asap.
  11. ajohnson
    ajohnson Medium Load Member
    580
    1,368
    Jan 6, 2016
    chicago area
    Must have at least 20/40 WITH glasses. Does not matter how bad you are without glasses
