Voltage meter showing incorrect reading
Discussion in 'Questions From New Drivers' started by Arannsingh, Aug 30, 2018.
  1. Arannsingh
    Arannsingh Bobtail Member
    Aug 30, 2018
    My 2007 D12 Volvo as been showing incorrect reading on the voltage meter inside (digital meter). The batteries are fine I tested them with a multimeter and the truck off and was reading 12.5 but the meter thats build in is showing 12.5 to 20v. I'm just wondering what's going and how it can damage my truck
  3. Ridgeline
    22,720
    123,220
    Did you check the voltage with a multimeter while the truck is running?
    bigguns Thanks this.
  4. Farmerbob1
    Farmerbob1 Road Train Member
    3,685
    5,792
    Jan 17, 2017
    When you tested the battery voltage, did you test each battery independently, while disconnected from all other batteries?
    A broken plate or two in a couple batteries can throw some truly weird readings.
    If any individual battery reads significantly different from the others, either high or low, replace it.
  5. shogun
    shogun Road Train Member
    6,075
    72,161
    Jan 23, 2009
    Doing a regen
    If it’s jumping around it’s possibly your frame ground. Otherwise, your voltage regulator may be going bad and it’s going to cook your batteries. Your truck ECM cannot handle 20 volts, you need to check the voltage coming from the alternator under load.
    Arannsingh, x1Heavy and Farmerbob1 Thank this.
  6. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    Regulator is bad would be my first guess. Just about all the computer stuff is going to get burned out from within, cooked to junk in a jiffy at 20 volts. Might even total that truck.
  7. Arannsingh
    Aug 30, 2018
    No I tested the batteries as a unit wired in parallel. I try that though thanks you
    Farmerbob1 Thanks this.
  8. Justrucking2
    Justrucking2 Road Train Member
    3,211
    4,295
    Sep 12, 2017
    Plymouth MI
    Could be the/a ground or the alternator. Normally when the volt gauge spikes, it is a sign that the alternator is failing. Let it go to far, you can do some serious and expensive damage to the electrical system. Have the alternator inspected and get under the truck, start at the battery box and start inspecting the cables. A 2007 unit, odds are you will need to pull and replace some cable, and clean up a few grounds, unless you keep track of that stuff. I have a feeling you do not, as I didn't either until I got under mine and had to replace 100 feet of that cable.. ;-)
  9. Ridgeline
    22,720
    123,220
    OK I guess troubleshooting 101 is out the door.
    dibstr Thanks this.
  10. Farmerbob1
    3,685
    5,792
    Jan 17, 2017
    I'll admit to not being a diesel mechanic, but looking for component failure in the simplest high potential source of failure should be a good place to start, if the truck isn't giving error codes, right?
    What would you do first? Real question. Not sarcasm.
  11. Ridgeline
    22,720
    123,220
    I posted exactly what I would do, look at the votage at the batteries while it is running, if it is stable, then it could be other issues.
    x1Heavy, AModelCat and Farmerbob1 Thank this.
