Volvo climate control unit
Discussion in 'Volvo Forum' started by dphillips, May 3, 2018.
  1. dphillips
    dphillips Light Load Member
    82
    8
    May 14, 2013
    I have a 07 Volvo 670 the the the climate control unit is not working and that part is more expensive than a compressor which is ridiculous the guy said I got coffee on it and now it's sticky and not working before I spend $450 on this thing is there a way to take it apart and fix it has anyone ever done this?
  3. nasriza
    nasriza Road Train Member
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    i have dealt with volvo for a long time and i have tried but never been able to succesfully fix one so i would just bite the bullet and buy a new one
    Oldironfan and dphillips Thank this.
  4. Snailexpress
    2,675
    6,068
    Apr 28, 2014
    Rocky
    Not working? What exactly it does. Not cooling?
  5. dphillips
    82
    8
    May 14, 2013
    Yeah it's not turning the AC I guess the AC button specifically was damaged he was able to jump start the compressor so it's not getting a signal from the AC switch
  6. Snailexpress
    2,675
    6,068
    Apr 28, 2014
    Rocky
    Wait to buy. I will find how to check you can do it. also you can find AC computer on salvage sites for penny.
    KB3MMX Thanks this.
  7. Snailexpress
    2,675
    6,068
    Apr 28, 2014
    Rocky
    This troubleshooting isn't right. Too many things can prevent AC start. Some of really stupid things as reverse ON switch. Usually if button is lighted means switch is ON. Not in my truck. My AC is on when switch is dark. So check with wire diagram is power get to AC computer and binary switch state.
    If AC computer has buttons sticky remove the computer unplug all connectors and wash it in warm water until buttons are free. Shake the water well out use some blow air. Then submerge computer in rubbing alcohol. Shake the alcohol out blow it with air and let it dry. I did it to wash out spilled coke.
    AC troubleshooting is here Help with Volvo VNL780 A/C
    KB3MMX Thanks this.
  8. Ridgeline
    22,244
    114,618
    The control unit in the cab is just a head unit that tells the body computer what you want. The ecm controls the compressor after the signal comes from the body computer.
    You can't fix the head unit, it most likely shorted out.
    Replace it with a used one, there are a lot of them floating around.
    KB3MMX Thanks this.
  9. Gentlemanfarmer
    Gentlemanfarmer Medium Load Member
    365
    384
    Feb 26, 2010
    Greenville, FL
    Have you changed the in cab filter? If the in cab filter, mounted under the bottom bunk on the passenger side is dirty, it prevents air flow and the compressor will not circulate air. Also, if the control unit has to be replaced, then spend the $450 to have it done right and stay cool.
    Oldironfan Thanks this.
  10. AlBig
    AlBig Light Load Member
    145
    52
    Apr 16, 2017
    Yes it's easy to open. Just need some small stars kind tool. Clean it with some brake or carb cleaner and than with low air. Starter fluid should work too
  11. QUALITYTRUCK
    1,801
    1,762
    Jun 14, 2009
    romulus,mi
    Use aerosol contact cleaner.
