Volvo d13 2013 truck will not go over 45mph? Egr stuck open?
Discussion in 'Volvo Forum' started by Tcainmayne, Dec 20, 2018.
  1. Tcainmayne
    Tcainmayne Light Load Member
    55
    11
    Dec 20, 2018
    My truck won’t go over 45mph while pulling a load or when bobtailing been having problems for 3 weeks still can’t figure out the problem I changed map sensor then one shop put a egr differential pressure sensor update kit (what ever the hell that is) and didn’t fix the problem the truck Regens good this and that but was put on a computer while loaded and it shows 0 fuel pressure when it hit 45 mph took to volvo and was told my egr is stuck open and egr cooler needed to be changed but I’m not sure if this will fix the problem has anybody else have this problem before please help
  3. GypsyWanderlust
    GypsyWanderlust Medium Load Member
    386
    568
    Jan 1, 2018
    How many miles are on it? A friend had a similar problem with his Mack and the same engine. I’ll ask him today what it was.
  4. Tcainmayne
    55
    11
    Dec 20, 2018
    It has 601,000 miles on it I also change fuel filters also still no change
  5. Newto Trucking
    Newto Trucking Medium Load Member
    359
    225
    Dec 26, 2013
    NE Illinois
    Do you have any codes?? Does the truck ask you to do parked regen??
  6. Tcainmayne
    55
    11
    Dec 20, 2018
    My codes was for the turbo and I replaced that and still same problem and the truck don’t ask for a park regen
  7. nasriza
    nasriza Road Train Member
    2,398
    2,074
    Feb 1, 2013
    Chicago, IL
    what code do you exactly have for the turbo and what did you replace, possible you have a serious boost leak somewhere as it is normally the case with this engines.
  8. Tcainmayne
    55
    11
    Dec 20, 2018
    It was 1127 fmi 8
    KB3MMX Thanks this.
  9. KB3MMX
    KB3MMX Road Train Member
    3,075
    2,596
    Dec 29, 2014
    Orrstown, PA
    0 fuel pressure when it hits 45mph .... Yeah that's why it won't go any faster.
    Fuel pump air leak in fuel line or collapsed liner in fuel line
    Clearly starving for fuel
    Need much more info on truck.
    Any other things going on?
    Hard starting?
    shogun Thanks this.
  10. Tcainmayne
    55
    11
    Dec 20, 2018
    No hard start it nothing truck is normal until I put a load behind it then soon as I hit 45 it start to hesitate it cut off on me one time when the mph dropped all the way to 5 mph but I changed the fuel differential sensor and it stopped now it just won’t go over 45 Volvo says my egr is stuck open plus my egr cooler was bad it failed the pressure test
  11. Tcainmayne
    55
    11
    Dec 20, 2018
    No parked regen one shop did a force regen on it but still didn’t work truck still had the same problem
