VOLVO I-SHIFT SHIFTS
Discussion in 'Ask An Owner Operator' started by 760 HwyRider, Apr 18, 2023.
  1. 760 HwyRider
    760 HwyRider Bobtail Member
    Have a question,if someone could answer,or explain.
    I have Volvo with I-Shift transmission,and for some reason it's starting always from 2nd gear,loaded,bobtail don't matter.Is that something I should worry about,is it easy fix,or whatever is,I would like to know.
    Thank you.
  3. Siinman
    Siinman Road Train Member
    5,264
    13,304
    Mar 5, 2017
    Kansas City, MO.
    It is in the programming of the truck. I would have the Parameters changed.
    ducnut, 86scotty and 760 HwyRider Thank this.
  4. Judge
    87,398
    I start in 2nd gear loaded.
    3rd Empty.
    4th. Bobtail
    Numb, 86scotty and Siinman Thank this.
  5. Coronado2020
    Coronado2020 Light Load Member
    50
    139
    Jul 7, 2020
    AZ
    It’s normal and programmed that way driver. Nothing to worry about.
    ducnut and 760 HwyRider Thank this.
  6. Jacoooooooo
    Jacoooooooo Heavy Load Member
    747
    1,054
    Oct 20, 2013
    It will start from first when heavy loaded uphill. It may start from third on a downhill empty. First time having an automated transmission?
    You can manually select a gear before starting if you feel like you know better.
  7. Stringb8n
    Stringb8n Road Train Member
    1,573
    1,980
    Sep 27, 2015
    Mine does this too, also an Ishift. But not all the time. You sure you aren't bumping the shifter to make it shift up? Sometimes if I set mine to 2nd before I take it off it will take off in 2nd every time. Other times it goes back to 1st (which I hate). When empty I can usually take off just fine in 3rd sometimes even when light. So I would say its normal but that is just me.
  8. MacLean
    MacLean Road Train Member
    1,299
    3,843
    Sep 12, 2017
    Perfectly normal for any transmission.
