Warning and OOS, should I change jobs?
Discussion in 'Experienced Truckers' Advice' started by marwan30, Aug 5, 2023.
  1. marwan30
    marwan30 Bobtail Member
    11
    11
    Aug 5, 2023
    I get warning and I be thinking to change my job did it hurt if I apply to other job
  3. buddyd157
    buddyd157 Road Train Member
    13,564
    34,840
    May 25, 2017
    under a shade tree
    well first, it's your job and duty to check registrations of any trailer and any tractor assigned to you, as well as insurance card and other important documents kept in the truck.
    so THAT one is on you for not catching it and taking care of it.
    the tire thing can also be on you if you did not check your tires good enough at the pre-trip, or even a post trip, even IF a post trip is not required, you should always check your vehicle when you are done for the day/night.
    you can of course always catch a nail or other debris in your tire, to cause a leak, but that is on you too, if you do not do a "walk around" each time you stop to "squirt the dirt", or stop for a break.
    so tell me, let's say you do get another job, would you be as ignorant to what YOU are supposed to be doing, as a responsibility as that professional driver..??
    or look for yet another, and another, and another job..???
  4. marwan30
    11
    11
    Aug 5, 2023
    I make a mistake and will not happen again just I’m scared for found a local job because I have 1 year experience now and I don’t want effects my CDL
    blairandgretchen Thanks this.
  5. buddyd157
    13,564
    34,840
    May 25, 2017
    under a shade tree
    local job may, or may not check the safe stats on you
    treat the equipment like your life depended on it, cuz it does.
    after 1 year, you should have known better...no excuses.
    hope not dumb twucker Thanks this.
  6. blairandgretchen
    13,377
    71,914
    Dec 9, 2011
    South west Missouri
    The safety points follow the driver from company to company now.
  7. marwan30
    11
    11
    Aug 5, 2023
    So do you think will be hard for found other job local
  8. buddyd157
    13,564
    34,840
    May 25, 2017
    under a shade tree
    go back and re-read what i said about local jobs.
    self explanatory.
    good luck.
    i'm out.
    drvrtech77 and blairandgretchen Thank this.
  9. blairandgretchen
    13,377
    71,914
    Dec 9, 2011
    South west Missouri
    Dude - glad to hear it. You’re retired. Your signature says it all.
    Why you don’t take up fly fishing or something of benefit to you, rather than beating the tar out of folks here that are new/scared/uninformed -
    Dude asked a question - he’s concerned. He didn’t kill a bus load full of nuns.
  10. Milr72
    Milr72 Medium Load Member
    569
    1,381
    Dec 16, 2011
    S W Missouri
    He's the new X-1 Heavy!
    Siinman, exhausted379, Oxbow and 4 others Thank this.
  11. bryan21384
    bryan21384 Road Train Member
    14,910
    32,341
    Sep 18, 2009
    Memphis, TN
    Some companies, whether OTR or local, will look at how many CSA points you have. I know for a fact Magnum does. They turned me down 4 years ago because I had a lot of violations. It was my fault for staying too long with a company that had a cheap owner. That company is long gone and out of business. I had accumulated a lot of CSA points over the 5 years I worked for that company. Magnum requires a score to be 30 and under. Those infractions you have aren't that big of a deal. You should still be able to find work anywhere. Those aren't moving violations. It isn't like you had a bad accident or something. We all make mistakes early on in our careers. It's only way you learn quite from them, quite frankly. Don't worry yourself about these inspections. Just learn from them and do more detailed pre trips. Even to this day, I sometimes miss things on my pre/post trips.
