Water in fuel in my Freightliner M2, where is it coming from?
Discussion in 'Experienced Truckers' Advice' started by Chad82, Apr 29, 2021.
  1. Chad82
    Chad82 Bobtail Member
    I'm driving a Frieghliner M2. I keep having water in the fuel. I drained the tank and changed the filters. Two days later there's water in the fuel again. Does anyone know where the water could be coming from and how to fix it?
  3. SmallPackage
    5,494
    17,483
    Dec 20, 2019
    Marion Texas
    If it’s rain water getting in there and they are square tanks there is only two places to look. The fill cap or the fuel level gauge or gauge block-off plate on top of tank. The common standard little Freightliner caps that have the three or four 3/8 inch round dimples on the top of them are not air tight.
    On my FL60 straight truck the rain water when parked would run straight down the front corners of the box body and flow onto the tank fill cap. I had to divert the water with something sometimes to keep it out of the open neck if I was fueling during a rain.
    Newer M2’s use the same tanks and caps.
    Flint1 and slow.rider Thank this.
  4. 062
    062 Road Train Member
    6,227
    33,497
    Oct 20, 2013
    Then there’s the obvious... change fuel stops o_O
    JoeyJunk, Cowboyrich and mustang190 Thank this.
  5. Jenkins2020
    Jenkins2020 Light Load Member
    204
    446
    May 28, 2020
    I had this happen recently. It was the ####ty fuel I was getting from a local truck stop. Once I changed locations, it went away. You may be able to Google the place where you got fuel from and see if anyone else had the same problem.
    Magoo1968 and Farmerbob1 Thank this.
  6. flood
    flood Road Train Member
    4,161
    4,031
    Dec 25, 2010
    Do you really have water in your fuel....??
    My cummins is giving me the water on fuel light but I have no water in my fuel... I do have a bad sensor on the water separator
  7. Farmerbob1
    Farmerbob1 Road Train Member
    3,685
    5,791
    Jan 17, 2017
    Ah. Are you sure it's water, and not coolant?
    Monitor your radiator coolant level very closely. Coolant can get into your fuel in several ways, depending on what equipment you have. Some of those ways can mean an engine rebuild. Others might need much less serious work done. Replacing some fuel filter assemblies, for example.
    John E. and AModelCat Thank this.
  8. mustang190
    mustang190 Road Train Member
    2,847
    6,121
    Jan 18, 2011
    Florida Panhandle
    Do you keep your tanks full? Condensation is bad this time of year especially in the south.
    Farmerbob1 Thanks this.
  9. uncleal13
    uncleal13 Road Train Member
    3,797
    6,295
    Apr 9, 2009
    Humboldt, Sk
    Check to see if your engine has a water drain on the bottom of the fuel filter assembly like on a DD15. Even if you change the filters on that engine, the water drain still has to be opened.
    Farmerbob1 and John E. Thank this.
