Webasto bunk heater problem
Discussion in 'Ask An Owner Operator' started by Hendrix404, Oct 1, 2020.
  1. Hendrix404
    Hendrix404 Bobtail Member
    5
    Good day to you all, fellow drivers!
    I've got Cascadia 2019 with Webasto bunk heater. Every time I turn it on, couple hours later my 3000 watt Power Inverter shuts down. The only thing that plugged in is a fridge. Does it mean that my batteries are too weak for Webasto + fridge combination?
    Another concern is - shouldn't engine start automatically, when batteries are drained out?
  3. DUNE-T
    DUNE-T Road Train Member
    6,953
    16,865
    May 10, 2015
    Detroit, MI
    How old are your batteries?
  4. Hendrix404
    5
    13 month old or so
  5. blairandgretchen
    13,380
    71,961
    Dec 9, 2011
    South west Missouri
    The Webasto doesn’t draw a lot - the fridge is more of a drain.
    Only time I had this problem was with weak batteries - have them load tested.
  6. 86scotty
    86scotty Road Train Member
    4,498
    12,168
    Aug 27, 2017
    Appalachia
    Simple stuff first. Clean and tighten terminals. Check ground to frame.
    blairandgretchen and rachi Thank this.
