With winter coming on, my thoughts turned to some of the cold weather issues. The truck I drive has one of those Webasto bunk heaters that seems to be fired by the diesel fuel. I have fired it up and it works well as far as heating things.
My question is, are these things "bullet-proof" safe or is it necessary to keep a close eye on them? Especially as it pertains to carbon monoxide (CO) poisoning, but also general fire issues.
Any of you experienced drivers have any thoughts on the matter?
Thanks!
Webasto Safety Concerns
Discussion in 'Experienced Truckers' Advice' started by Giorgio, Sep 14, 2011.
Read this thread!
http://www.thetruckersreport.com/tr...almost-didnt-wake-up-morning.html#post2147410otherhalftw, Giorgio, BigJohn54 and 1 other person Thank this. -
Be aware that the heater will stop working if your fuel gels up in extremly cold conditions. I have had this happen in -40F cold and woke up absolutely frozen in the sleeper. Allways be prepared with winter clothing in the truck.
follow directions on it to a T. It's not hard to screw a Webasto up. Always make sure you give it time to go through it's shutdown sequence, or the igniter/glow plug will carbon up, and it will quit working.
The only problem I ever had was that it kept popping coolant hose clamps, keep a few handy.
Get a carbon monoxide detector and keep it in the sleeper.
Good idea!
Even after I repaired the exhaust leak I was a bit skittish about going to sleep. Kept a couple windows cracked. One close call is plenty for me. I got a CO detector, but forgot it at home. It's packed now. -
