Weekly 34 hour resets
Discussion in 'Questions From New Drivers' started by Holdthec, Jul 24, 2016.
  1. Holdthec
    Holdthec Bobtail Member
    Jul 24, 2016
    is it possible to do 34 resets every 7 days if you so choose?
    astracat111 Thanks this.
  3. carramrod32
    carramrod32 Heavy Load Member
    712
    793
    Sep 7, 2008
    Midwest
    You can do a 34 every week or run off recap just depends what kind of outfit you work for.
    astracat111 and Holdthec Thank this.
  4. Holdthec
    Jul 24, 2016
    Is that something you can find out about a company pre-employment? I signed up for CDL school and will begin classes soon so im kind of clueless
    carramrod32 Thanks this.
  5. carramrod32
    712
    793
    Sep 7, 2008
    Midwest
    So for example if you are home daily and weekends off then a 34 or actually a bit longer would be happening. Or out 5 days home 2 you would do a 34. It just depends on the way the company runs. Since you are just starting out you would most likely be going otr and be gone 2 to 3 weeks at a time, which you would either run on recap or do a 34 reset. It depends how hard you run and the hours you use. You can find out a lot before employment just don't believe a recruiter to be 100 percent truthful. This site has a lot of good info on it, use it to your advantage.
    Holdthec and firemedic2816 Thank this.
  6. sherlock510
    sherlock510 Road Train Member
    1,066
    1,058
    Jul 26, 2011
    Intercontinental.
    It's possible, but there's really no point.
    You'd essentially have to turn down loads if you chose to reset when ya don't have to. The company probably wouldn't like a reset every week if you're OTR, because it's wasting time... Each company has their own policy and you'll have an idea of how they run during orientation.
  7. scottied67
    scottied67 Road Train Member
    10,826
    12,671
    Mar 14, 2010
    california norte
    For a while they restricted us to one 34 hour break in 7 days. I mean you could do multiple ones but only one counted. That has changed and you can do a 34 hour break every other day if you wanted and it resets your 70 over and over no restriction.
    I try to run closer to 10 hours a day 7 days a week then take 17-30 hours off and pick up 10 hours a day for the next 7 days so a '24' give or take hours off is equivalent to 34 hours off.
  8. Wooly Rhino
    Wooly Rhino Road Train Member
    3,367
    5,648
    Jul 6, 2008
    Liberty, Missouri
    In ten years of trucking, I have had to do exactly one 34 hour restart and that was very early in my career. I did it in Morgantown West Virginia (Don Knotts hometown). Coming out of driving school, I had the idea that 34 hour restart were the norm. It is one of the many things that get screwed into your head that are wrong.
    Lepton1 Thanks this.
  9. xsetra
    xsetra Road Train Member
    5,117
    6,989
    Aug 21, 2011
    As mentioned above. 34 is not required and you can do as often as you want to reset your 70 clock.
    Good luck
  10. xsetra
    5,117
    6,989
    Aug 21, 2011
    yes
    tinytim and tucker Thank this.
  11. Driver91
    Driver91 Medium Load Member
    479
    287
    Jun 28, 2015
    I'm home every weekend. Usually from Friday night till Sunday night or Monday morning. So yes my dispatchers want us to get a 34 weekly, but most times I get more than 34. Just how our freight runs, so they bring us back home for a 34. I've never had to take one on the road luckily.
